Hello all, as described in my title I have a sceptre X20G Naga-II that has no power, no lights are coming on, on the panel buttons or screen. I have trouble shooted this monitor with no luck so far, what I have done so far is replaced a switching transistor (Q11) that was shorted, replaced all capacitors on ps board because I don’t have a esr meter I went ahead and just replaced all of them on the ps board, no caps were bulging before replacement, I also reflowed solder joints on the transformers. Checked the fuses f1 and f2 on the ps board with fluke 115 DMM both fuses were good. I’m stumped and don’t know where to go next with this project, also I can’t find a service manual for this monitor anywhere. I marked the voltage readings I’m getting from the pins that feed the main board hoping someone can tell me if anything looks off. Oh I also forgot to mention I marked Zener diode (ZD102) and Signal Diode (D103) on the bottom view of ps board with Permanent marker because I was getting a reading of .041 on the signal diode and .136 on the Zener Diode I Placed the negative or black lead on the cathode side of the diode when I got these readings, DMM set to diode check, but I dont know how to get the values to replace these components, any help would be appreciated. Thanks in advance!
Sceptre X20G NAGA-II no power
Re: Sceptre X20G NAGA-II no power
Lecture 1. When troubleshooting it is important to take a methodical approach. Recognizing symptoms can help avoid wasting time and money.
Lecture 2. You have given us an incredible amount of detail, and some very good pictures. One is missing and another leaves a lot to be desired, however.
Preliminary results. Some of the voltages are unusual (9.1V), others are common (5.3V, 12.9V). What is missing seem to be the control signals to the inverter. The power supply / inverter seems to be working properly, there are problems on the signal card.
Your tasks.
On the picture of the power supply / inverter there are two heat sinks above the transformers (large yellow objects) and two more immediately to the right. The first two are for the power transistors, the second pair are for the output diodes. What are the part numbers of the components mounted on the heat sinks mid-right on the board?
I've marked up the picture of the signal board. There are 5 LDO regulators circled in yellow, I've numbered the pins on one of them. For each of these, report the following information - part number, voltage on pins 1, 2, and 3 (use a mounting screw as the ground point).
There are two switching regulators circled in blue. What are the part numbers of these?
I'd like a picture of the monitor showing all the boards in place and the cables linking them.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Thanks for all the information! I will complete the tasks you laid out for me to do as soon as I get off work this afternoon and will post the results. thanks again.“Be Who You Are and Say What You Feel Because Those Who Mind Don't Matter and Those Who Matter Don't Mind.”Comment
Got my tasks completed. The part numbers mid right of the ps board are as follows I also marked on the picture where D107 and U105 are located.
D107= PEC 503
ER1002FCT
U105= L7805CV
WCC1A0346
MOROCCO
I also have the part number from the other heatsink mounted parts if needed later, I did not want to flood you with information you did not need or ask for.
The LDO regulator part number is the same for all 5 components
part# 4DH 17-33. And the readings are
U9= (1) 0 (2) 3.3V (3) 5.3V
U22= (1) 0 (2) 3.3V (3) 5.3V
U27= (1) 0 (2) 3.3V (3) 4.9V
U20= (1) 0 (2) 3.3V (3) 5.3V
U21= (1) 0 (2) 3.3V (3) 5.3V
Switching regulator part numbers are both the same.
JM46AB
LM25765
-ADJ P+
Hope this helps please let me know if you need any more information. Also keep in mind I'm taking these pics with my iphone, the wife lost the charger for our good cam. if you need better pics I will buy a new charger just let me know.
JM46AB
LM25765
-ADJ P+
http://pdf1.alldatasheet.com/datashe.../LM2576-5.html
Now measure the DC voltage of each of the 5 pins with respect to ground. I normally put my black probe on a screw on the logic board for ground. Report all readings for all chips.--- begin sig file ---
--- end sig file ---Comment
217V???
Are you measuring DC voltage across the legs of the large filter capacitor? Black probe on negative and red probe on positive leg of the capacitor?
Warning this is high voltage.--- begin sig file ---
Actually I was using a ground screw and got that reading. I rechecked it with your direction and got 394.4 V DC“Be Who You Are and Say What You Feel Because Those Who Mind Don't Matter and Those Who Matter Don't Mind.”Comment
Q4= (1) 8.84 V
(2) 2.5 V
(3) 0
(4) 1.22 V
(5) 0
Q11= (1) 12.52 V
(2) 5.0 V
(3) 0
(4) 1.22 V
(5) 0“Be Who You Are and Say What You Feel Because Those Who Mind Don't Matter and Those Who Matter Don't Mind.”Comment
http://en.wikipedia.org/wiki/Power_factor
Normally, we expect 120AC x 1.414 = 170V DC. With PFC, that DC voltage gets boosted up well over 300V DC.--- begin sig file ---
Wait a minute, the actual part number is LM2576S, not ML25765 (now that I see the close up photo of Q11). Correct datasheet is at
http://pdf1.alldatasheet.com/datashe...H/LM2576S.html
With the -ADJ in the part number, I *think* Q4 and Q11 are good based on the output voltages on pin 2.Last edited by retiredcaps; 02-29-2012, 09:36 PM.--- begin sig file ---
thanks for the replies and links its good information I'm always up to learn something new. do you know of anything else I can check..“Be Who You Are and Say What You Feel Because Those Who Mind Don't Matter and Those Who Matter Don't Mind.”Comment
This monitor does have a PFC front end which seems to be working.
The voltages on the LDO regulators are all fine, the buck regulators are also reasonable, but my question is why is there no 1.8 volts?
Other than hoping I could see something with a better picture of the signal board, I can't think of any further steps.
PlainBillLast edited by PlainBill; 02-29-2012, 09:54 PM.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
also I noticed that the green LED "circled red" is the only light that comes on and it is a very faint light that blinks slowly. the other LED next to it does not even come on. I didn't know if this would tell you something. The 2 wires that feed this board go to the ps.“Be Who You Are and Say What You Feel Because Those Who Mind Don't Matter and Those Who Matter Don't Mind.”Comment
PlainBill... I dont know why it wouldn't come on when I plugged it in during tests? but I'm not going to complain it is just very puzzling to me. I'm thinking the switching transistor I replaced must have been the problem but why I couldnt get it to respond when the casing was off is a mystery to me..
You are 2nd person within the last 36 hours to experience that.
https://www.badcaps.net/forum/showthread.php?t=19354--- begin sig file ---
this may be a stupid question but there was a plate that was screwed on across the 2 heatsinks on the ps board I had this off during tests I just assumed it was there for thermal reasons.. am I right about this or was this some kind of ground??“Be Who You Are and Say What You Feel Because Those Who Mind Don't Matter and Those Who Matter Don't Mind.”Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI was working on this CNC machine today found no keyboard functioning no control relay powering on
The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
Found shorted diodes on main controller relays there are 3 of them that... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
