LG FLATRON W2042TQ-BF. blue led - no display
    Re: LG FLATRON W2042TQ-BF. blue led - no display
    The way I remove the chip like that is to cut the legs, then use 40 Watts Iron and heat up the big tab while adding more solder to it, the melted solder will help keep maintaining the heat, then you just twist the body to get it off the board.
    • diavollo
      • Sep 2013
      • România
      i need to make same operation.must be something wrong with this model.
      • number22
        • Dec 2010
        • 12
        Took mine apart and replacing some capacitors before destroying MOSFETSs
        need to replace 3 of 16v 1000uf, 3 of 35v 470uf ,1 of 50V 33uf.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • ttmi100x
          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
          by ttmi100x
          Greetings everyone,
          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
          Upon closer inspection...
          07-31-2024, 06:36 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
