I have a Westinghouse 19" widescreen monitor that I have recapped with United Chemi Con KZE series capacitors, and it is still only partially working. When I first opened it about half of the filter caps were bulged.
After putting the board back into the monitor and powering it up, I noticed the LCD was displaying the image, but there was no backlight. After that I used another board to power the backlights, and the monitor functioned perfectly (the display board was still being powered via the original board). All four CCFL's were tested individually, and they all lit.
I have recapped about 20 monitors, with a nearly perfect record. Help me keep it that way. Below are pictures of the front and back of the board.
The seven brown capacitors on the right are the ones I replaced. I did not replace the two small caps directly above the caution statement about the fuse (starter caps? - they are 50V and 47uF/22uF). There is a hum coming from the Delta transformer.
Any help is greatly appreciated.
EDIT: Removed pictures from post to add to managed attachments.
