Sony SDM-HS75P
  • Joun
    • Jul 2011
    • 191
    • Greece
    Sony SDM-HS75P
    Hello everyone..
    I have this Sony SDM-HS75P monitor that doesn't power at all.
    No lights,nothing ..I thought that it got some diodes shorted and it burn its fuse but everything seems to be OK.Voltage on primare cap measures fine generally the primary side looks good.
    On the output voltage connector I measure 12volts and 5volts,but: I have a strange voltage of 1.5 volts that doesn't look good..Do you think that this is the problem and can that prevent it from powering on or do I have to look at the vga board?
    Thank you.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Sony SDM-HS75P
    If you have no power led, then you have to look at the vga board. Post pictures. There may be some voltage regulators and one or more of them may have gone bad?
    --- begin sig file ---
    --- end sig file ---
    • Joun
      • Jul 2011
      • 191
      • Greece
      Re: Sony SDM-HS75P
      Thank you for your answer..
      I will post pictures tomorrow, I just want to ask you about that 1.5 volt on the connector, is that normal?
      Yes there are two regulators, I'll check them.
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Sony SDM-HS75P
        On some power boards there is a legend that lists all the expected voltages. Sometimes it is on the front, other times it is on the back.
        If there is no legend, then 1.5V could be normal as there are many functions like brightness control, dimming, etc that use lower voltages.
        5V is usually standby. 12V is probably for the inverter section.
        • Joun
          • Jul 2011
          • 191
          • Greece
          Re: Sony SDM-HS75P
          The truth is that nothing seems strange or burned..So I guess power supply is fine.
          I will check the regulators on VGA board and post pictures.
          • selldoor
            Slow Learner
            • 7870
            Re: Sony SDM-HS75P
            Hi- Looks like someone has had a go at this board? I have marked soldering areas in yellow which might need re -visiting.The Big cap especially looks poor.
            The component at U802( Marked in red) looks to be melted? is that just my eyesight?
            The area marked in violet looks like a solder bridge but appears cracked?
            If it is meant to bridge it needs redoing. If its not it needs undoing.
            Id have thought the 1.5 volts should be 3.3 but cant find much out about this board.
            it is a 715G1447-1-GP
            The Big Cap is a UCC are the others the same manufacturer?.
            The vga board may be a different manufacturer what are the caps on that. You should post a picture - may help others in future and explain the 1.5v.
            There is also a thread on a polish site which appears to have the same symptoms someone has suggested U202 may be faulty but I cant see a U202 on the board? can you see one or is on the vga?
            http://translate.google.com/translat...3.html&act=url
            • Joun
              • Jul 2011
              • 191
              • Greece
              Re: Sony SDM-HS75P
              Hello,thank you for your answer.
              Component U802 looks melted,but it isn't.It is just flux on it.Same goes for primary cap..It has lot of flux on solder(not from me), I try to redo soldering points on it.
              Exactly the same goes for the two diodes you marked with yellow.I have desolder them for measuring and didn't clean paste at all.
              All in all it doesn't look like someone has messed with it before..
              P.S Thanks for the polish link!
              • Joun
                • Jul 2011
                • 191
                • Greece
                Re: Sony SDM-HS75P
                Here are the VGA board pictures..Regulators looks and measures just fine, 3.3Volts and 1.8Volts as they should.Measure voltages at the connector that goes to button board and see there are 12 and 5 volts present.
                Any ideas?
                P.S I didn't want to use flash so photos are uneven lighted.Everythink on boards are optically OK.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Re: Sony SDM-HS75P
                  Any ideas?
                  Can you indicate on the logic board which pin is 1.5V DC?
                  Can you also mark up the logic board picture to show the DC voltages from the power board on the different color connectors?
                  • Joun
                    • Jul 2011
                    • 191
                    • Greece
                    Re: Sony SDM-HS75P
                    There you are..
                    I was wrong about the 1.5V voltage..There isn't any.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Re: Sony SDM-HS75P
                      Okay, without a schematic or some legend, I can't tell which of the pins that read 0.0V is the PS_ON pin.
                      Some will read 0.0V because it is ground. You can do a quick resistance check with respect to ground to see which read less than 1.0 ohms. Those that do are likely to be ground. Those that are left might be PS_ON.
                      What I'm about to suggest might damage your monitor so you have to decide for yourself.
                      Disconnect the main board from the power board.
                      For those pins that are left at 0.0VDC try hooking up 2 AA cells in series to get 3.0V DC. Apply 3.0V DC to the unknown pins and see if the backlight comes on. If it does, then you have found PS_ON.
                      From there, it is a matter of tracing PS_ON on the logic board to see why there is no 3.? V DC.
                      • Joun
                        • Jul 2011
                        • 191
                        • Greece
                        Re: Sony SDM-HS75P
                        Nice trick! Will do so when I get back.. Just a question: The upper connector goes to button board and has lots of 3.3V voltages.
                        Is that irrelevant?
                        Thank you.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Re: Sony SDM-HS75P
                          Is that irrelevant?
                          I can't see the top of the picture, but I assumed (maybe incorrectly) that cable went to the front keyboard.
                          The lower connector is the only one to the power board so PS_ON has to be here.
                          The other way to force the backlight on is to tie a resistor between 5V standby and PS_ON as tom66 and PlainBill have mentioned a few times here.
                          https://www.badcaps.net/forum/showpo...9&postcount=45
                          • Joun
                            • Jul 2011
                            • 191
                            • Greece
                            Re: Sony SDM-HS75P
                            Yes,that's right.You can see it in the pictures I have posted earlier(post #8 )..
                            I will try the resistor trick,thank you very much!
                            • Joun
                              • Jul 2011
                              • 191
                              • Greece
                              Re: Sony SDM-HS75P
                              Well resistor trick worked just fine..
                              PS_ON pin is the brown one( at the bottom left of the connector )
                              I removed the connector from VGA board and place the resistor between this pin and the white one that has 4.88volts.The thing is that the backlight lit ,but brown pin had too high voltage about 4.6Volts( maybe was drawing less current that expected? )
                              With a little try and era found that it needed 33K resistor to drop voltage at 3.2volts.Now the backlight is lighting..
                              What does that mean?
                              • selldoor
                                Slow Learner
                                • 7870
                                Re: Sony SDM-HS75P
                                Hi just changed my"Status" from senior member to slow learner as senior member may suggest I know what im talking about.
                                As Retired caps said "From there, it is a matter of tracing PS_ON on the logic board to see why there is no 3.? V DC."
                                As a suggestion this may get us back to the Polish Page and my question re U202. On logic board back is U202 the one in the top left hand corner.
                                I think it may be labelled as 74 LVC14AB. 60450D If so, the data sheet is attached and perhaps someone can suggest how to test it?
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Re: Sony SDM-HS75P
                                  It's easy. It's a 14 pin IC, pin 7 is Gnd, pin 14 is power. Pins 1, 3, 5, 9, 11, and 13 are inputs. Pins 2, 4, 6, 8, 10, and 12 are outputs. The association is 1 - 2, 3 - 4, .... 13 - 12. And it's an inverter - if pin 1 is high, 2 should be low.
                                  Now my question to you is: If pin 1 is low (0volts) and pin 14 is 5 volts, what voltage should you see on pin 2?
                                  PlainBill
                                  • Joun
                                    • Jul 2011
                                    • 191
                                    • Greece
                                    Re: Sony SDM-HS75P
                                    PlainBill
                                    Well I didn't quite understand that:You're asking to see what my knowledges are,or you asking to check voltages and post results?
                                    I'm saying that because you wrote "should you see" not "do you see" on your post..
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Re: Sony SDM-HS75P
                                      It is a quiz to see if you understand what he wrote. I have seen him ask others as well.
                                      You can verify your answer by measuring the IC.
                                      • Joun
                                        • Jul 2011
                                        • 191
                                        • Greece
                                        Re: Sony SDM-HS75P
                                        Well I am an electrical engineer, I don't have to verify my answer( I mean,I'm sure about it) ..I even can't measure the IC since I'm away now.
                                        Since it is an inverter, pin 2 must have the opposite state of pin 1, if pin 1 is 0volts pin 2 is 5volts..
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                          09-06-2024, 05:30 AM
                                          Sony VAIO SVF1541M1E Notebook Fit E Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF1541M1E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF1541M1E boardview and SVF1541M1E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony...
