dell se198wfpf repair
  • Ωωεη G
    • Jan 2012
    Hello
    I have a monitor that recently blew up when plugged in.
    There was a pop and then then wonderful smell.
    Upon opening the case and removing the board, there is zero visible damage.
    I suspect the fuse blew.
    Does anyone have a quick fix or possible ideas for fixing this.
    I live in a tiny town- and I can guarantee I will not be able to source parts here.
    I will probably need to order parts.
    The search yielded results, but all posts contained boards that had visible damage. I see nothing.
    The monitor is dead - without any sign of life whatsoever.
    Thank you
    ----------------------------below is my normal typing style----------
    hey..
    plugged in pop - smell
    board looks fine
    thinking maybe just the fuse blue ?
    thoughts? ideas -
    black screen - no led
  • retiredcaps
    • Apr 2010
    • 9271
    Re: dell se198wfpf repair
    1) A good fuse should measure less than 1.0 ohms.
    2) Check your bridge rectifier for shorts.
    3) Check your power mosfet for shorts.
    4) If you don't know what #2 and #3 are, post a picture of your board following the instructions below exactly.
    #2 and #3 are the most likely candidates to take out the fuse.
    If you wrote in that style above, I would not taken the time to answer. Many others here would have done the same and moved onto the next thread. This is not twitter or some phone text forum.
    And NO, I'm not grumpy or an English major, but think, garbage in, garbage out.
    --- begin sig file ---
    --- end sig file ---
    • Ωωεη G
      • Jan 2012
      wow - i have been away for a bit
      just to think about it - - i think it is a fuse
      i will go check the forum rules - i usually do - because i have come acrooss lots of
      enal type - so as i say - englidh ust must be
      Her Majesty the Queen of England's english ...
      same reply as alwways
      if you are her - i will be more than happy to use the queens english
      iii if yu are just a "queen" - i may even consider that - too. ( 2 )
      but like i said - i usually check the forum rules -
      ifr it ain't in da rulez den it ain't goonna happn babeeee
      • retiredcaps
        • Apr 2010
        • 9271
        You are now officially on your own. I don't have time to deal with smartasses.
        https://www.badcaps.net/forum/announcement.php?f=24
        Posting rules:
        This forum was created to be a technical support forum primarily for the do-it-yourselfers who choose to repair their own boards. Any and all technical questions are welcome!
        3) Please use COMPLETE sentences, punctuation, and grammar! Nobody is perfect, hence, a spelling error on occasion is no biggie. However, posts/threads that are unreadable will be deleted. This includes any and all forms of 'ebonics', leet crap, chatroom jargon, and 'text message' shorthand and slang. This forum is not a chatroom/text message, please use full words and complete sentences.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          hey..
          board looks fine
          thoughts? ideas -
          that would have simply been deleted....because not only does it make you look like a tard that shouldn't be working on electronics, it drops the overall IQ of the forum a few points.... Seriously? You type like that? That may be the cool thing to do on facebook or some other teenage hangout....but anywhere else in the world, its just laughable gibberish.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            even on facebook it would be bad...
            Learn proper english, use it, and play the BCN game again.
            sigpic
            (Insert witty quote here)
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • corrize
              A funny fuse story – Lumix LX100 II
              by corrize
              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
              10-19-2023, 09:58 AM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
            • diamon
              Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
              by diamon
              I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
              Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
              Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
              Pictures of these boards:
              Dell Latitude 5520 https://www.ebay.com/itm/256052956663
              Dell Latitude 5530 https://www.ebay.com/itm/125844181534
              Dell...
              02-28-2024, 12:51 PM
            • lalle-
              Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
              by lalle-
              Hello!
              I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
              [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
              I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
              The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
              I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
              08-11-2024, 02:01 PM
