Westinghouse L2046nv
  • Shredasaurus
    • Jan 2012
    • 17
    Hello everyone, this is my first post. I have 2 Westinghouse L2046NV monitors that I purchased a couple of years ago. The first display went out on me about a year and a half ago. I got online and found some fantastic info on this forum from many other people who were having the same exact problem. I replaced all the suggested caps as well as the blown mini fuse (parts list included in the thread, talk about awesome lol) and I was back in business.
    So anyhow....i play in a band and we have a practice room setup with a bit of gear. My Bassist fires up his amplifier the other day and it trips the circuit breaker in the room (same circuit the monitor was plugged into). When I got the power back on, the monitor was completely out...no flashing light, no power indicator, it just doesn't turn on at all.
    So I open her up thinking that I probably have a blown fuse. I checked with my multi-meter for continuity on all the mini fuses that I could spot in the circuit. as well as the initial fuse where the 110v enters the circuit. As far as I can tell all my fuses are still good. What I did notice was that the 2200uF cap and the 1000uF cap were bulged and leaking. So I ordered a replacement kit that had all of the caps for this board. I replaced those two that looked bad and I am still getting nothing.
    I took the Same board (assuming that this is the the power supply?) out of my other working monitor and put it in the bad monitor and it fired right up so I know that it is something on this board that has gone bad. I unfortunately don't really know where to go from here. I plugged the board up and I can verify that it is getting power beyond the first fuse but from there I have no idea what I should be looking for. I am an electrician for my Day job and have dabbled with some electronics but I really don't have the background to be able to sit down and troubleshoot this.
    Is there really any sense in swapping out the other caps if they aren't visibly damaged? Is there somewhere else in this circuit I should be checking? I am assuming there is at least one transformer in the circuit but I am not even sure what voltage it should be operating at.
    Thanks in advance for any help.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Westinghouse L2046nv
    1) Using continuity to test fuses is not a good test. Here is why. Some multimeters beep "continuous" for resistance readings less than 1800 ohms.
    A good fuse should measure less than 1.0 ohms.
    2) Yes, Capxon makes terrible quality caps and don't last very long. So change out all the remaining Capxon caps. See standard answer below.
    3) However, I suspect your bridge rectifier is shorted. See the component circled in red.
    If you number the pins 1, 2, 3, and 4, measure the resistance between pins 1-2, 1-3, 1-4, 2-3, 2-4, and 3-4. You can do this initially in circuit.
    Any reading less than 30 ohms suggests a short and you should verify out of circuit (i.e. desolder and retest).
    4) --- standard answer, regulars can skip ---
    https://www.badcaps.net/forum/showpo...84&postcount=3
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      5) If the bridge rectifier is not shorted, you should get roughly 165 V DC across the big filter capacitor.
      6) On the connector between the power and main/logic board, there is a legend silkscreened on the board. If everything is working properly you should get those secondary DC voltages.
      • Shredasaurus
        • Jan 2012
        • 17
        -So after reading the standard answer....a bad capacitor can result in keeping the monitor from powering up at all and not be visibly messed up if it is out of tolerance? I apologize, I am still trying to wrap my head around the capacitors role in the circuit.
        -RetiredCaps thank you for the quick response. I measured 128 V DC across the filter cap so this would rule out the Rectifier correct?
        -I am a little confused by the Pin out legend on the main power board. It has 7 labels on the left side of the connector ......Ground, Ground, +5v, +13.8v, Mute, ADP-, ADL- On but there are 8 pins total. The right side has EVA, GND, DET, 5v+, W-adj, Shut, ADR+, ADL+.....I am assuming that the left label is for the upper level of pins and the Right label is for the lower pins?
        Also, when inspecting where these pins are soldered to the PCB, I noticed 2 components......R104 and R105 (resistors?). R105 has what looks like a 0 printed in the center and R104 looks like it is no longer there......I am trying to get a clear picture but it is super tiny. Thanks again.
        • retiredcaps
          • Apr 2010
          • 9271
          Yes. A single bad capacitor could keep the entire circuit from working.
          Your bridge rectifier isn't shorted, but it still could be bad.
          If you are in the USA, 120 V AC mains should be rectified to 170 V DC.
          The formula is 120 x 1.414 = roughly 170 V DC.
          If you are reading 128 V DC, please remeasure and confirm that number.
          If that is the true number, then you have to measure the bridge rectifier for DC voltage. There should be two + and two -. Each should measure about 85V. 85 x 2 = 170.
          PS. I forgot to mention this is all high voltage since you are measuring the hot side. I didn't mention earlier since you said you were an electrican.
          Probably.
          Yes. R is resistor. 0 is a 0 ohm resistor. It is possible R104 was not ever present.
          See "Reference designations"
          http://en.wikipedia.org/wiki/Electro...e_designations
          • jetadm123
            • 2169
            As retiredcaps mentioned, you should see approx 165VDC across the large cap. Since you're seeing much less voltage, try checking the bridge rectifier per his directions on post #2, step 3. When performing these tests, make sure the monitor is unplugged.
            Looks like retiredcaps already beat me to the punchline.
            • PlainBill
              • Feb 2009
              • 7034
              I'm expecting you will find that the bridge rectifier is fine, but the large (100uF?, 450 Volt) cap is bad. (I am taking you at your word that you put one probe on each leg of the large cap).
              If one diode in the bridge is shorted, it will blow the fuse or take out some other component in the input line.
              If one diode in the bridge is open, the cap will still charge to 167 volts, however it will be receiving only half the input waveform.
              As an exercise to the student, draw a simple bridge rectifier circuit and show the current flow through the diodes for each half wave of the AC input.
              PlainBill
              • Shredasaurus
                • Jan 2012
                • 17
                Apologies, It was a long day yesterday and I got confused when typing my initial reply. Re-Testing the two pins from the large capacitor I am reading 169 Vdc. Testing the bridge rectifier I get 57.7 vdc between pins 1 and 2...0 volts Dc between pins 2 and 3 , 59vDc between pins 3 and 4 and 169 volts DC between pins 1 and 4.
                I still intend to replace the rest of the Caps today but is there anything else I should check?
                Oh and yes I realize that this is hi-voltage but it never hurts to have a little safety reminder
                Thanks again!
                • jetadm123
                  • 2169
                  Thanks again!
                  1) with power off and monitor unplugged, try checking diode D107 for shorts.
                  2) with power off and monitor unplugged, check transistor Q102 (mounted on heatsink) for shorts.
                  3) with power on, check voltage across startup cap CE107.
                  • Shredasaurus
                    • Jan 2012
                    • 17
                    JetAdm123 I replaced the rest of the caps before i saw your reply. So i now have all brand new caps.
                    The components you mentioned....D107 and Q102 they should be on the underside of the board? Having trouble locating them but I probably need to find a magnifying glass.
                    The voltage on CE107....AC or DC?
                    Thanks again for the help
                    • jetadm123
                      • 2169
                      All components are on top of board (see photo) and the silkscreening may be hidden by the white glue. I believe CE107 is a 47uf 50V cap. Measure voltage using the DC scale. See photo for the other components.
                      • Shredasaurus
                        • Jan 2012
                        • 17
                        OK I have my multimeter set on 2k Ohms. When I put my 2 leads on the 2 pins of d107 it reads OL. When I test the 3 pins of Q102 it gives me 0 resistance and continuity between all three (1 and 2, 1 and 3, 2 and 3) etc..I will test the voltage on that cap in a bit.
                        • Shredasaurus
                          • Jan 2012
                          • 17
                          I am seeing 0 volts DC at CE107.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            If you reverse the leads, it should measure between 0.4 and 0.7 V.
                            Desolder Q102 and verify that you get the same readings out of circuit.
                            If it is still shorted, list the part number of the chip.
                            • Shredasaurus
                              • Jan 2012
                              • 17
                              So with no power on the circuit and my meter set to ohms that resistor should read .4 or .7? I am getting 0L no matter which way I orient my test leads.
                              I am going to Desolder Q102 in a bit to re-test.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                To test diodes, set your multimeter to the diode test position. A good diode should measure 0L one way, and between 0.4 to 0.7V the other way. Remember a diode should only let current go one way and block it the other way.
                                • Shredasaurus
                                  • Jan 2012
                                  • 17
                                  Slapping my forehead lol, didn't have my meter set to diode test. Ok so I got OL one way and .485 the other way. So this Diode is good right?
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    Yes.
                                    We have a animated gif for
                                    • Shredasaurus
                                      • Jan 2012
                                      • 17
                                      Desoldered Q102....with my meter set to 200ohms I am reading 7.5ohms between 1 and 2. 5.6ohms between 1 and 3 and 2.1 ohms between pins 2 and 3.
                                      This is what appears to be printed on the component.
                                      p6nk60zfp
                                      gk24w v6
                                      chn 71.8
                                      Thanks!
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        p6nk60zfp
                                        Your Fet is definitely shorted. $1.59 at digikey.com
                                        http://search.digikey.com/scripts/Dk...ords=p6nk60zfp
                                        With USPS 1st class mail, it should be less than $3 and you will get it in 48 hours.
                                        I still recommend changing out ALL the Capxon caps on the power board.
                                          Westinghouse L2210NW LCD monitor - bad caps repair
                                          by momaka
                                          Here's another LCD monitor repair: Westinghouse L2210NW.
                                          Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                          I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                          Pictures of the monitor outside/case after a brief...
                                          01-11-2021, 01:14 AM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
