HP 22in desktop monitor
    The monitor has been acting up for about a month or so with vertical lines on the whole screen. No problems with backlighting at all. When I turn it on sometimes it does it shortly after start up other times it may take 20 minutes before it starts. Then it does the lines for anywhere from a minute to 20 minutes then stops and is good till the next time that I turn the monitor on from a cold start.
    What should I look for when I open it up? And where should I look? I am planning on a new monitor but would like to fix this one if possible and have 2 22in monitors. Sorry I don't have a model number as I am at work at the moment.
    Re: HP 22in desktop monitor
    This sounds like either bad caps or caps with high ESR (ohms).
    Take it apart and have a look. If you do spot bad caps, see
    --- standard answer below ---
    https://www.badcaps.net/forum/showpo...84&postcount=3
    --- begin sig file ---
    --- end sig file ---
      Thanks will do. Thanks for the reply.
        As caps warm up the ESR drops which is why it takes 20 minutes to come on.
