HP 22in desktop monitor
  • Xtremepayne
    • Jul 2011
    • 6
    The monitor has been acting up for about a month or so with vertical lines on the whole screen. No problems with backlighting at all. When I turn it on sometimes it does it shortly after start up other times it may take 20 minutes before it starts. Then it does the lines for anywhere from a minute to 20 minutes then stops and is good till the next time that I turn the monitor on from a cold start.
    What should I look for when I open it up? And where should I look? I am planning on a new monitor but would like to fix this one if possible and have 2 22in monitors. Sorry I don't have a model number as I am at work at the moment.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: HP 22in desktop monitor
    This sounds like either bad caps or caps with high ESR (ohms).
    Take it apart and have a look. If you do spot bad caps, see
    --- standard answer below ---
    https://www.badcaps.net/forum/showpo...84&postcount=3
    --- begin sig file ---
    --- end sig file ---
    • Xtremepayne
      • Jul 2011
      • 6
      Thanks will do. Thanks for the reply.
      • retiredcaps
        • Apr 2010
        • 9271
        As caps warm up the ESR drops which is why it takes 20 minutes to come on.
          HP ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor ProDesk 400 i3-6100 Specification for Upgrade or Repair
          This specification for the HP ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor boardview and ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
          09-12-2024, 03:28 PM
          by momaka
          03-15-2023, 10:17 PM
        • reessi
          ACER BM320 Monitor - Horizonal Flickering Lines After a While
          by reessi
          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
          They are black on the right and gradually fade to nothing on the far left.
          They start either after 5 mins or up to 2 hours after so annoying for testing.
          They flicker continuously very fast! With a slight pause milli-second every second.
          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
          I tested each half by removing the first the left flex from...
          06-03-2025, 09:58 AM
        • Kikerumbo
          Mi Curved Gaming Monitor 34" - Horizontal lines
          by Kikerumbo
          Thanks in advance for any help you can provide.
          I have a Mi Curved Gaming Monitor 34". A few weeks ago it started to show (or not showing) horizontal lines. Of course, it's outside of the warranty period.
          After some hours of reading and watching videos I disassembled the monitor and checked the ribbons that go from the TCON board to the panel PCB. If I disconnect the ribbon for the right side of the panel, the other half shows a perfect image. I ordered a "new" TCON, installed it and the issue persists so that tells me it must...
          03-14-2024, 02:48 PM
          HP Slim Desktop S01-aF0009nf Slim Desktop J5005 Specification for Upgrade or Repair
          This specification for the HP Slim Desktop S01-aF0009nf can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0009nf boardview and Slim Desktop S01-aF0009nf schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
