Viewsonic VA2216w
    master hoarder
    • May 2008
    • 12170
    Re: Viewsonic VA2216w
    Originally posted by Joun
    I'll try to read part number..But since it's not open circuit or short circuit I guess it's OK..
    Yes, it's good. Like Pedro said, this is usually a schottky type diode, hence the low reading you got.
    • Joun
      • Jul 2011
      • 191
      • Greece
      Well then I guess I'll keep it for spares..Thanks everyone for answering.
      • retiredcaps
        • Apr 2010
        • 9271
        I have try to re-seat ribbon cable allready
        Did you also trying cleaning the cable ends (each side) with a bit of isopropyl alcohol?
        --- begin sig file ---
        --- end sig file ---
        • Joun
          • Jul 2011
          • 191
          • Greece
          They look clean enough, but I will try that anyway...
          • hexid
            • Feb 2012
            IT's sims like problem sit in t-con
            becouse there are 3 man have the same priblem with the same monitor
            i have it too CLAA215FA 21.5
            • Joun
              • Jul 2011
              • 191
              • Greece
              #26
              I guess you couldn't fix it,right?
              • hexid
                • Feb 2012
                #27
                no success
                  by momaka
                  03-15-2023, 10:17 PM
                • ant3202
                  HP 27es - LED monitor - Monitor Flashing On - Off
                  by ant3202
                  Hi Everyone
                  Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                  https://www.badcaps.net/forum/troubl...lashing-on-off
                  The monitor is HP 27es LED Monitor
                  https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                  The monitor will randomly blackout and display no signal and will recover again.
                  Sometimes need to power and off again to restore the display but...
                  03-20-2025, 07:30 PM
                • Rick_1234
                  by Rick_1234
                  Good evening, gentlemen.
                  Things I tried
                  06-22-2024, 04:44 PM
                  Wise Wing F199 19'' LCD monitor - recapped
                  by momaka
                  Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                  I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                  When I saw the Craigslist post, I wasn't...
                  08-24-2020, 10:58 AM
                • sew333
                  Pc shutdown, monitor flickered with no signal after 10 seconds
                  by sew333
                  My pc:
                  10850K stock 4800mhz stock Kraken X73 good temps
                  2x16 GB DDR4 GSKILL 3000mhz XMP
                  Seasonic Tx-850 Ultra Titanium
                  Gigabyte Rtx 3090 Gaming OC
                  Aorus Z490 Pro Gaming
                  1 TB SSD
                  4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                  Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                  Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                  Power...
                  02-22-2022, 10:27 AM
