LCD Dell E176FPf
  • r3m1x
    • Oct 2011
    • 28
    LCD Dell E176FPf
    hey guys, i'm back!! i have another monitor to repair. this monitor is a LCD Dell E176FPf. The problem with this monitor is that it doesn't turn on at all. I opened it up, checked for bad caps in the power supply, but i can't spot any. i'm attaching pictures for your advice. thanks for all your help guys!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: LCD Dell E176FPf
    1) A good fuse measures less than 1.0 ohms. Check it (highlighted in yellow).
    2) If the fuse is good, see if secondary DC voltages appear on the logic part of the board. There are 3 voltage regulators marked in red. Measure each pin except the tab with respect to cold ground (use a mounting screw).
    List the part number and DC voltage for each pin.
    3) If all DC voltages are 0.0 V DC, then measure the DC voltage across the legs of the 100uF 450 V cap (marked in blue). It should be 165 V DC if you are in North America.
    4) What is the DC voltage across the startup cap (circled in lime green)? Is it steady or fluctuating?
    --- begin sig file ---
    --- end sig file ---
    • PlainBill
      • Feb 2009
      • 7034
      This monitor and equivalents are notorious as unrepairable. The fools who designed the firmware save some operating parameters in program memory - the 8 pin IC with the paint dot next to the processor. Eventually the firmware gets corrupted, and the processor won't work. If the proper voltages are present on the processor end of the card, your only hope is finding a source of a chip with the firmware preloaded.
      PlainBill
      • it.vendor
        • Dec 2013
        • 14
        • pakistan
        i have same model but .....on off button is not working.....seem like firm ware programe fault.if any body have that in bin file.....plz.
        • Fuzer
          • Jun 2015
          • 11
          • Portugal
          I there
          I Have one of these to repair, check the mosfet, the resistors from the PWM IC. This is a common problem on this type of Power supplys.
          Compliments
          • wattage
            AOC AG493UCX 49-inch monitor - Firmware request
            by wattage
            Hello Badcaps Community,
            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
            07-13-2025, 04:41 PM
            Dell Thunderbolt Firmware
            by SMDFlea
            Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
            Some models have a choice of 2 different firmwares, it depends on the dell SKU.
            The SKU is in brackets (****)
            EDIT: NVM65...
            01-26-2025, 06:22 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
            by momaka
            03-15-2023, 10:17 PM
