Samsung Synchmaster 2693HM WHITE SCREEN
  • OncleOh
    replied
    Re: Samsung Synchmaster 2693HM WHITE SCREEN
    @mockingbird
    Why Yikes!
    I used 105degre ones , have to check.
    So what do you suggest about t-con board?
    Regards!
    Leo
  • mockingbird
    replied
    Yikes!
    Did you use Jamicon as replacements?
  • OncleOh
    replied
    T-con board right side. Previous picture was left side.
    Regards!
    Leo
  • OncleOh
    replied
    T-con board.
    Regards!
    Leo
  • OncleOh
    replied
    Here are the photos of the PSU.
    Note that all the caps on the PSU except the big one are changed.
    Regards!
    Leo
    replied
    Originally posted by OncleOh
    forgot to mention that after white screen it goest to black (white faids to black)
    I had a monitor with those same problems before. Like yours, the fuse on the t-con was good. Problem turned out to be a shorted tiny ceramic cap the secondary boosted rail on the t-con board. Fairly easy fix.
    Your monitor's t-con is probably very different from mine, but if you just want to get an idea of the problem, you can find my thread here:
    https://www.badcaps.net/forum/showthread.php?t=12210
    Would the pictures of the boards help?
    Yes, very much!
    You should be able to spot a round inductor on your t-con. The area of interest on the t-con is usually around that inductor. I suggest you take several pictures: one of the whole t-con board, and several close-ups of the area around the round inductor.
    Also, as a very primitive test, power on the monitor and see if anything gets hot on the t-con board, especially any ICs and diodes in the area of the round inductor. You may have to cycle the power to the monitor on and off a few times for this. Be careful, as components can get hot very quickly if there is a fault. Let me know if you find any that do.
  • OncleOh
    replied
    Regards!
    Leo
  • OncleOh
    replied
    @PlainBill
    Already checked all the cables all seem ok, have to check voltages.
    Any other idea?
    Regards!
    Leo
  • PlainBill
    replied
    i have a samsung 2693HM with white scren when it powers off, already replaced all caps on the power board and still the same result, cheched the fuses on T-CON board and all ok.
    Is it possibel taht the inverter board is bad, i changed the caps on the inverter board too?
    Regards!
    Leo
    No. If the inverter wasn't working you would have a black screen.
    Triple check the seating of the cable from the signal board to the tcon, and the flex strips from the tcon to the panel. If there is a separate power cable to the tcon check that too.
    PlainBill
    PlainBill
  • OncleOh
    started a topic Samsung Synchmaster 2693HM WHITE SCREEN
    Regards!
    Leo
  • harp
    White screen repairs
    by harp
    To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
    Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
    On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
    05-13-2024, 03:43 AM
  • Chrissygizmo
    samsung galaxy ao2s very temperamental after screen replaced
    by Chrissygizmo
    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
    Ive eventually managed to get it on and working but it's very temperamental...
    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
    05-26-2024, 12:05 AM
  • JunkmanJimbo
    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
    by JunkmanJimbo
    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
    No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
    Please help. Thanks in advance!
    08-12-2025, 11:45 AM
  • Kiberge
    Samsung LH82QENELGC/EN Help needed - Static line on screen
    by Kiberge
    HI guys!
    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
    04-22-2024, 11:28 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
