Asus VK193S Backlight problem.
  • BenCesur
    • Jun 2011
    • 35
    Hi everyone!
    I have asus vk 193s monitor. when i open the monitor , monitor's light closing after 5 seconds. shun looking i can see the there is imagine. but light does not lighting. if i restart the monitor does lighting 5 seconds. i examineted card. measure capacitors , they are working. i have changed marked points in picture. my problem is continues to. I could not find a guide on internet.
    Yes, gentlemen! What would you recommend me to do.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Asus VK193S Backlight problem.
    1. Please do not post pictures inline. Instead, use 'Manage Attachments' - below the test entry area.
    2. You have 'Two seconds to black'. Retiredcaps tells how to troubleshoot it in this thread.
    PlainBill
    • BenCesur
      • Jun 2011
      • 35
      PlainBill
      Ok Bill . Thanks.
      I have read that topic. But I could not find a solution.
      • PlainBill
        • Feb 2009
        • 7034
        Originally posted by BenCesur
        Ok Bill . Thanks.
        What tests have you performed? Did you check the resistances of the transformer secondaries? Substitute known good CCFLs?
        PlainBill
        • BenCesur
          • Jun 2011
          • 35
          The same problem was due to a monitor. The problem as described above. Capacitors for the other elements are also clean clean. But the image disappears after 5 seconds.
          • jayoung
            • May 2011
            • 172
            The problem described is referred to as "2 seconds to black." Troubleshoot as 2 seconds to black. Various causes possible: bad caps, shorted transistors, open fuses, bad transformer, bad ccfl (bulb or wiring), etc.
            https://www.badcaps.net/forum/showthread.php?t=10419
            PlainBill was asking what tests in that thread you had performed and what, if any, were the results.
            FYI, capacitors can fail without any visible signs.
            • BenCesur
              • Jun 2011
              • 35
              HKC-LCDMT19C moment in my hand monitor. Two flat-panel display monitor controller has the Realtek.
              And so far the problem of 2 seconds for the first time I saw this on two monitors.
              Had written in some forums that this problem caused by high current.
              • DanPoka
                by DanPoka
                02-15-2025, 05:05 AM
              • Dobrowol
                Asus GA402RK keyboard and kb backlight problem
                by Dobrowol
                Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                04-28-2025, 04:30 PM
              • Honziq
                Backlight problem - Asus M3200WU, board Gapal LA-L291p
                by Honziq
                I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
                I was repaired many backlights before but this design i will not understand.
                For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
                Can someone explain me please what to do, what to check?
                Thanks....
                11-20-2024, 01:24 PM
              • tmhobadcap
                LG 24MP56HQ-P Monitor Backlight problem?
                by tmhobadcap
                I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
                Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
                I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
                10-13-2021, 01:52 PM
              • tmhobadcap
                by tmhobadcap
                10-12-2021, 01:43 PM
