Dell 2407 inverter caps
  • btb88
    • Nov 2011
    • 13
    I just did a search and couldn't find a direct answer to my quandary.
    I've replaced the PSU caps on this Dell 2407 wfp monitor, its 5 or so years old and I've noticed the odd flicker so wanted to do some preventative cap changing. So, PSU all done and dusted.
    When I came to look at the caps on the inverter board the ones I planned to use didn't look as 'beefy' as the ones in situ and wondered if anyone could confirm my choice is a good one...I've got 220uF 35v Rubycon ZFK series.
    On paper they seem up to spec, (I think), but wanted to double check before I put them in. All I know so far is they should be able to take 1200mA ripple current.
    Does anyone know if they OK to use? Thank you for any advice.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell 2407 inverter caps
    Where did you buy them? I've done a cursory search, and they are not a current Rubycon series, and I can't find a reference to any ZFK capacitor series.
    Nichicon HC or Panasonic FM series would be acceptable for this application.
    PlainBill
    • btb88
      • Nov 2011
      • 13
      Thanks for your quick reply. I bought them from RS, they seem to be a current item
      http://uk.rs-online.com/web/p/products/7258161/
      I don't mind ordering some others, but I've got these and if possible would like to use them.
      • jetadm123
        • 2169
        Spec sheet for the ZLK series below. Probably not as popular because of the limited number of capacitance and voltage values. Looks like a very good choice for your needs.
        • btb88
          • Nov 2011
          • 13
          Originally posted by jetadm123
          Spec sheet for the ZLK series below. Looks like a very good choice for your needs.
          Thanks for looking over the spec. I thought they should be suitable, but looked a bit 'weedy' (ie they are thinner!), next to the originals and I had second thoughts.
          I'll go ahead and fit them.
          Much appreciated.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
            by momaka
            03-12-2025, 03:42 PM
          • JFA
            Honda generator inverter 230v 1900uf caps
            by JFA
            I have a Honda generator with a faulty inverter. The inverter is encased in black resin with just the tops of a dozen small electrolytic caps and four 230v 1900uf electrolytic caps poking out of the top of the resin. The plastic cover of one of the 230v caps was burned off but there was no sign of bulging and the capacitor can was in good condition. The heat source looks likely to be from the outside rather than from the component itself but since the inverter is basically unrepairable, I chiseled away and removed the capacitor. I had to destroy the capacitor so had no chance to test it but it...
            11-28-2021, 03:30 AM
          • huzo
            DELL Latitude 3500 no image, fan max speed, caps lock frozen
            by huzo
            Dell latitude 3500
            Board BOLT-L UMA MB
            17938-1
            FW8G6$LA
            when i press the power, fan goes full speed, power button lights up , and caps lock light is on, the screen polarises, goes dark,no backlight...All voltages present, except PL4701, but that's probably for GPU power later....
            I've tried a few dumps from posts, it always acts the same, so i thin it's not a bios issue...
            No shorts found on the board...
            What should i try next?
            10-06-2024, 02:15 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
