Westinghouse LCM-19w4 Vertical Line on LCD Screen
  • DTLMG
    • Nov 2011
    • 37
    I received this monitor from a school and it would not power up. All the caps were bulged. I did a successful cap replacement, but when i turned it on got this Vertical Line on the Right Hand side of the screen.
    The line is constant and is there from the startup process all the way through until the machine is completely booted. My limited repair experience is telling me that this is an LCD panal and is not repairable.
    Would you pros agree?
    The green and red on the screen are just from the screen saver.
    Second question..Would there have been a way I could have checked the LCD panel before I did the recap to see if it was good? I get lots of non working monitors given to me and its disapointing to go through all the work only to find out i have a bad LCD.
  • alexanna
    • Mar 2010
    • 1346
    Re: Westinghouse LCM-19w4 Vertical Line on LCD Screen
    Yes it's not repairable,But you do have a good set of test CCFLs,
    As far as lines go that could be difficult,unless you wanted to try the panel in another monitor.
    Broken LCD can be located by careful examination,I have used an external inverter to check the integrity of the screen and look for any pressure marks
    • DTLMG
      • Nov 2011
      • 37
      I have been trying to build an external inverter for testing back lights.. see this thread... no responses.. https://www.badcaps.net/forum/showthread.php?t=17723
      When you say put the panel in another monitor you mean another westinghouse right? I tried to put it into an HP power inverter and got nothing.. no backlight or anything.. OF course the ribbon configuration is different.
      • alexanna
        • Mar 2010
        • 1346
        I have a backlight tester that I use on some occasions.
        However I don't use for testing a 2 second to black problem, When the monitor powers on it runs a series of tests to make sure the backlight system is working properly. Just because a backlight will light in the tester doesn't always mean that it will perform in the monitor. It really depends the tolerances that are programmed into the inverter.
        I have always had better luck using known good CCFLs in the monitor that is exhibiting a problem.
        I guess I am lucky I always have numerous monitors setting around, so I experiment a lot and can find another screen that's compatible. I think the biggest problem you will run across is cracked or broken screens. I just don't run into a lot of monitors with colored lines running down them.
        • DTLMG
          • Nov 2011
          • 37
          Problem Solved
          Problem solved! I am learning that many back light assemblies, PSU, etc are interchangable. I happened to have a V87 19 inch monitor waiting to be recapped... I looked at backlight assy and it was a drop in fit. REassembled and it has been on for the past 4 hours. Now if i can just figure out what fits what, I ll keep this in mind when rummaging through the schools recycable pile!
          • almarhum
            To fix laptop screen vertical line by working on its EDP cable
            by almarhum
            Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
            As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
            05-07-2024, 02:12 PM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • ahoonid
            MacBook A1990 vertical stripes on external screen
            by ahoonid
            Hey everyone,
            I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
            The board is neat. Not opened before for sure. Just a little dust, nothing more.
            Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
            06-20-2025, 08:54 AM
          • Firentiosi
            1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
            by Firentiosi
            Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
            The issues are as follows: the...
            11-27-2024, 12:33 AM
