Westinghouse L2046NV 2 seconds to black
  • retiredcaps
    • Apr 2010
    • 9271
    #41
    Re: Westinghouse L2046NV 2 seconds to black
    Originally posted by Mr Bill
    here are the numbers for the rectifier
    1-2 5.97
    1-3 6.01
    1-4 12.84
    3-4 6.06
    Your bridge rectifier is bad.
    The burnt r103 doesnt have any numbers on it. R104 looks identical and it also has no numers on it. R104 measured .01 ohms while r103 measured .07 ohms
    Without identifiers it is hard to tell if those readings are correct or not. They do make 0 Ohm smd resistors so those readings could be right depending on the resistance of your test leads.
    --- begin sig file ---
    --- end sig file ---
    • Mr Bill
      • Nov 2011
      • 648
      i ordered the bridge rectifier from mouser and the fuse so we'll see if atleast gets me back to where i was a few hours ago.
      • alexanna
        • Mar 2010
        • 1346
        #43
        I f you can try to get Mouser to put a hold on your order, and add some things to it. These are not going to be that expensive and you will save on freight if they are needed.
        Blackrider1 put together a part list of some mosfets,I have included his attachment, of 4 pieces required.
        • Mr Bill
          • Nov 2011
          • 648
          I got the parts today. Changed the bridge rectifier, the fuse, and i went ahead and got the mosfets for giggles since all 4 were under $1 total. The thing fired right up. Have been running it for several hours now and still going.
          Thanks for all the advice retiredcaps and alexanna
          • alexanna
            • Mar 2010
            • 1346
            #45
            Besides replacing the bridge rectifier and the fuse.Do you know what cured the 2 sec problem?
            Was there a problem with the small MOSFETs?
            • Mr Bill
              • Nov 2011
              • 648
              I'm pretty sure it was the 2 small mosfets. When i was checking them i wasn't getting similar readings on both even after they were removed. So since i had to replace the fuse and bridge rectifier to fix my mistake and the fact that were fairly cheap i just went ahead and added them to the order aswell.
              • retiredcaps
                • Apr 2010
                • 9271
                #47
                If you still have the bad ones, try a simple resistance test between source-gate, source-drain, source-gate. Any reading under 30 Ohms confirms the short.
                I can't see the fuse and bridge rectifier causing 2 seconds to black.
                • Mr Bill
                  • Nov 2011
                  • 648
                  the fuse and bridge rectifier was from me flipping the board over and not having cardboard between the board and the back of the lcd panel.
                  The one mosfet had a real low resistance 1-2 ohm
                  • ttmi100x
                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                    by ttmi100x
                    Greetings everyone,
                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                    Upon closer inspection...
                    07-31-2024, 06:36 PM
                  • pandrew
                    Thinkpad T490 doesn't detect NVME
                    by pandrew
                    I have a Thinkpad T490 (NM-B901 Rev 1.0) that cannot detect an NVME M.2 SSD,
                    but it works fine with a SATA M.2 SSD.
                    When connecting an NVME M.2 SSD I get while booting:
                    "2101: Detection error on HDD0 (Main HDD)"
                    I can continue and boot a live linux distro from a USB stick, but it doesn't show up in lspci,
                    and I don't notice any relevant error messages in dmesg.
                    I have tried two different M.2 NVME SSDs (both working fine on a different machine),
                    and the behavior is the same.
                    I am pretty sure that all the important...
                    11-13-2023, 03:04 PM
                  • twonk9098
                    Lenovo Legion 5 high fan spin turns off after 34 seconds
                    by twonk9098
                    I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                    I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                    I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                    I have tried a few new bios but exactly...
                    07-14-2024, 11:19 AM
                  • Spoonicks
                    Samsung 2233SN no CFL backlight
                    by Spoonicks
                    Have a Samsung 2233SN with no CFL backlight. Testing with a flashlight, I can see the image is displayed, but the backlight fails after some seconds.
                    Sometimes, after being off for a while, the backlight will remain on for a couple minutes, but most of the times it fails immediately.
                    I tried to follow the guide present in this forum, but so far I haven't de-soldered any components. I need some advice on how to proceed to diagnose this display.
                    Following the guide I tested the following:
                    The transformer...
                    07-01-2023, 11:10 AM
                  • corrize
                    Where to find a very small fpc connector 0.3mm between 2 pins ?
                    by corrize
                    Hello, I search this connector (oxydated).
                    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                    Do you know how to find this connector please ? What is the exact name for find it ?
                    08-06-2024, 05:25 PM
