Viewsonic VA720 - 2 secs to black
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Viewsonic VA720 - 2 secs to black
    Originally posted by shovenose
    Now, how would I measure this on an analog multimeter?
    I don't know what your analog meter looks like, but I think there is a 1K and 10K setting? Use 10K Ohms to start.
    I'm assuming the inverter transformers are the ones market PT1 and PT2.
    I can't tell from the lack of a picture, but they are the ones that sit on the board with the ccfl plugs. The secondary pins might be the ones facing the the ccfl wires (blue pink).
    --- begin sig file ---
    --- end sig file ---
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I'll post a picture of both the inverter board and my multimeter tomorrow
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        This is my meter:
        And I'm fairly certain this is my inverter:
        • retiredcaps
          • Apr 2010
          • 9271
          Well, there is only one resistance setting so use that.
          Some of the pin combinations will be low Ohms (less than 1.0 Ohms), and others might show infinite. The one we are interested in is the "in between".
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            I did PT2 first.
            Pin layout:
            1 -| |= 5, 6
            2. -| |- 7
            3. -| |- 8
            4. -| |= 9, 10
            Note: 5-10 are evenly spaced in real life, just couldn't achieve that typed...
            I will add readings in a sec
            With my Digital multimeter on 2K Ohms
            1-2: -0.00
            1-3: .217
            1-4: .217
            1-5: 1.
            1-6: 1.
            1-7: 1.
            1-8: 1.
            1-9: 1.
            1-10: 1.
            How's that so far? Do you need more information?
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              1 -| |=5,6
              2 -| |- 7
              3 -| |- 8
              4 -| |=9,10
              Mann-Made Global Warming.
              - Dr Seuss
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Originally posted by PCBONEZ
                1 -| |- 5
                2 -| |- 6
                3 -| |- 7
                4 -| |- 8
                I updated my post.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  I did PT2 first.
                  1-3: .217
                  1-4: .217
                  217 Ohms looks like the magic number. Test PT1 pins 1-3 and 1-4.
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    PT1 results: 1-3: .216 1-4: .216
                    Looks like that one is OK
                    What's next?
                    Edit: I checked the PSU output again (now that I have a real meter lol). It's at a steady 12.26V when monitor is off. I turn it on, it dips to about 12.15V when the backlight is on. Then the backlight dies it goes back to 12.26V I guess the panel does not use much power as it is the same voltage as when off.
                    I hope those readings are normal.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      216 and 217 Ohms are within 3% of each other so we now can say the inverter transformer is likely good.
                      Edit: I checked the PSU output again (now that I have a real meter lol). It's at a steady 12.26V when monitor is off. I turn it on, it dips to about 12.15V when the backlight is on. Then the backlight dies it goes back to 12.26V.
                      That sounds right. The 12V rail is likely to be unregulated and will drop a bit with load.
                      1) On your inverter transformer, see if there is a SMD fuse or fuses. Two or more fuses will cause 2 seconds to black. If the inverter transformer only has 1 fuse, you wouldn't get 2 seconds to black at all.
                      2) If you have a spare lcd monitor kicking around that works, you can use the ccfl from that monitor to test out this one. You don't have to remove the ccfl from the working spare monitor. You just have to stretch the cable so that it reaches the other screen.
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        I'll look for fuses tomorrow.
                        I can't do the CCFL test because (while I do have 2 more monitors) I don't want to take them apart...
                        But the fuse idea sounds promising, I'll investigate that tomorrow. Those would be marked F or PF, right?
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Yes. On an older 2002 heritage NEC monitor, it had an inverter with 2 fuses on it.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            OK. I'll take a look tomorrow.
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              OK I found this big blue thing marked F1 and I measured it. It shows -0.00 on the 2k resistance setting.
                              I've circled and indicated F1 in the attached image
                              Anythnig else I should test?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #35
                                For fuses, you generally want the lowest Ohm setting on your manual ranging multimeter (200 Ohm) so you get more digit resolution. Having said that the fuse is good.
                                I can't tell from the pictures, but it looks like the ccfl cables are not the 2 wire scenario. If that is correct, you may have a hard time finding a compatible lcd screen that fit those connectors.
                                I picked up two 17 inch monitors and both have 2 seconds to black. I haven't had time yet to test them, but both have 3 wire connectors so at least I can stretch out the ccfl cables for testing purposes.
                                If you don't have the 3 wire compatible lcd, you will have to take apart the lcd panel and check for bad wiring and/or bad ccfl as I discussed in the earlier posts.
                                If you find bad wiring, you may be able to resolder the ends and make it work. If it is a bad ccfl, the cost of replacing it is questionable at best for an 8 year old 17 inch monitor, but that is for you to decide how to spend your money.
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  Any other possibilities for something to check? I really don't want to try taking apart the panel...
                                  • Scenic
                                    o.O
                                    • Sep 2007
                                    • 2640
                                    got a similar size panel you could connect to the inverter?
                                    or some of those modding CCFLs?
                                    If you connect these up and they stay on... well.. CCFL probs in the viewsonic panel
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      I don't have any spare CCFLs. So am I pretty much out of options?
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        If you look back at post #2, there are only the caps and ccfl lamps/wiring left to check. The fuse and inverter transformer test okay.
                                        I don't know if you want to spend the money to recap this old 2003 monitor. Caps would probably cost you $8 and it may NOT fix the problem.
                                        If you have the room, keep the monitor in case you get another one.
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • Ancient1
                                          Strange LG TV issue : Image vertical lines in black screen
                                          by Ancient1
                                          Hi
                                          Asking for a friend.
                                          I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                                          but here its the opposite !
                                          TV has new T-con = same issue
                                          A missing panel voltage would have global effect
                                          So , what should one do ? how can I find where the fault is ?
                                          Thanks !...
                                          02-05-2025, 03:37 PM
                                        • cjard
                                          Dell U27HM flickering/quarter image/black with smeared colors
                                          by cjard
                                          Hi all
                                          Wondering if I could get some insight on a Dell U27HM. First turned it on and the image was completely black. I later realised that if I dragged a window from one monitor to (the broken) other one then smeared colors would appear on the bottom 75% of the screen. After being on for several hours the top part of the screen started flickering showing an image (I have a video of this) and then suddenly the image appeared albeit rather fuzzy in the bottom 75% - image attached - and some hour later it now appears normal
                                          I do have two of these monitors so a compare/swap...
                                          09-13-2022, 07:12 AM
                                          MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                                          This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 01:58 PM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
