Cibox Flat Screen "two seconds to black" problem...
+ More Options
Posts
  • johnvvc
    • Nov 2011
    • 3
    Found this great site a few days ago so just testing the water with my first posting, hoping someone out there may be able to help me…
    I have a Cibox C1905 TFT LCD Monitor Model No. LW1922C which is giving me grief. It appears to be suffering from the ‘two seconds to black' problem.
    When I was given this monitor it would work but turn itself off after a minute or two. I changed a couple of electrolytics which were showing signs of distress, my capacitance meter confirming their value had decreased considerably. This however has not affected a cure and the time the monitor will stay on has progressively shortened.
    The on/off light is always on, turning green when the monitor ‘sees' an input. It stays green even when the picture goes off. Removing the source signal the on/off light turns amber but immediately goes green when the source is reconnected. The monitor then produces a picture for a very short while then goes off. Likewise switching the monitor off and on brings the picture back but quickly goes off again.
    I seem to be able to see faint images with a torch when the screen is off.
    Chyenne had a problem (not the same problem as mine) with a similar monitor and posted some pictures which I have gratefully borrowed (thank you Cheyenne):-
    https://www.badcaps.net/forum/attach...8&d=1320597822
    https://www.badcaps.net/forum/attach...9&d=1320597822
    I do not have an ESR meter so cannot measure the ESR of the electrolytics. I do have a couple of DVM's and a capacitance meter. I always feel happier using an analogue meter to check diodes etc and I have ordered an analogue meter off eBay.
    I'd be grateful for any help.
    Incidentally I found a great ‘how to' on fault finding on flat screens, sure it was on this site but I can't for the life of me find it now…
    Thanks.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Cibox Flat Screen "two seconds to black" problem...
    We prefer to see pictures of your boards for a number of reasons.
    1) Manufacturers make revisions or even complete board changes while keeping the same lcd model number.
    2) Your board, while perhaps the same, may have "aged" differently due to heat, cold, etc. Your board might have hot spots, poor soldering, glue turning conductive, etc.
    3) Just this month, someone posted I changed all the bloated caps, etc, but it doesn't work. It wasn't until he posted a picture of his recapped board that I spotted another bad capacitor.
    Now having said all the above, 2 seconds to black can be
    a) bad caps
    b) bad ccfl and/or wiring (mostly the return wire)
    c) bad inverter transformer
    All the above are explained in detail starting with posts #13 and #14 at
    https://www.badcaps.net/forum/showthread.php?t=10419
    --- begin sig file ---
    --- end sig file ---
    • johnvvc
      • Nov 2011
      • 3
      retiredcaps - thanks for your input.
      Thanks also for that 'how to' link - that was the one I couldn't find and which I'll go off and have a read.
      Apologies for not posting actual photographs, I can see why that wasn't such a good idea
      I'll have a good look at this monitor when my new analogue meter arrives and post again if - no when - I need more advice.
      Thank you for your time,
      John
      • johnvvc
        • Nov 2011
        • 3
        Had another look at this monitor.
        I suspect that one of the ccfl tubes is suspect. When I disconnect it and connect another one (while still inside another monitor!) the Cibox works - with 3 tubes instead of 4 running.
        As the picture is perfectly acceptable with 3 tubes, for now at least, I would like to run the monitor with 3 tubes but just disconnecting the suspect one and we're back to the old '2 seconds to black' scenario.
        I presume there must be some sensing circuit on the board that senses when a tube is disconnected (or broken) and turns the invertor off? If that is the case could I fool it into thinking it has 4 tubes connected... I'm thinking along the lines of some sort of dummy load, like a resistor across the tube socket.
        I'd welcome any ideas.
        • retiredcaps
          • Apr 2010
          • 9271
          Correct. The pwm inverter chip operates as an "all or nothing". All tubes work or none at all.
          Only one person has been able to get a "hack" to work. See
          https://www.badcaps.net/forum/showthread.php?t=13713
          If you try, this please post a picture and report back if it is working or not.
