failed ccfl
  • chetreynolds
    chet
    • Aug 2010
    • 77
    failed ccfl
    When one of the lamps the invertor will shutdown when it senses the bad ccfl . I have found that a .01 uf 1000v cap can be subsituted for the lamp and the invertor will continue to function . On displays with 4 lamps the missing lamp is not noticable .
  • retiredcaps
    • Apr 2010
    • 9271
    Re: failed ccfl
    Post a picture of this workaround using the manage attachments function.
    --- begin sig file ---
    --- end sig file ---
    • chetreynolds
      chet
      • Aug 2010
      • 77
      Re: failed ccfl
      Sorry I should made the post clearer . I was trying to pass on some info that may be helpfull .
      • retiredcaps
        • Apr 2010
        • 9271
        Re: failed ccfl
        I realized that and appreciate it. I wanted to see a picture of the workaround and see where/how you inserted the cap.
        • smason
          • 1652
          Re: failed ccfl
          Hmmm doesn't sound like too good an idea to me. How do you control the current?
          • PlainBill
            • Feb 2009
            • 7034
            Re: failed ccfl
            A CCFL exhibits a negative resistance curve.
            The inverter is designed to maintain a constant current output.
            I'd be interested in how warm the cap gets after the monitor has been on for an hour or more.
            PlainBill
            • mrfixit01
              • Mar 2011
              • 28
              Re: failed ccfl
              I think perhaps this would be good for a temporary workaround just to test the other ccfls? Maybe I should go back and retest my lcd to see if all the lamps are really bad or just one or two. Could make quite a difference in repair costs. Thanks for your post.
              • chetreynolds
                chet
                • Aug 2010
                • 77
                Re: failed ccfl
                I cliped the connector and soldered the cap to the connector leads and used heat shrink tubing for installation . I ran the monitor for over an hour and the cap remained cool . The display was a 22 inch with 4 lamps I could not see any degradation of the display .
                • ttmi100x
                  HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                  by ttmi100x
                  Greetings everyone,
                  I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                  The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                  Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                  Upon closer inspection...
                  07-31-2024, 06:36 PM
                • mikey5791
                  Help on Samsung Syncmaster T220 dead ccfl lamp
                  by mikey5791
                  This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                  Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                  10-18-2020, 03:17 AM
                • angelos
                  Hisense LCD42W60P Television
                  by angelos
                  Hi Guys,
                  I have this 2008 lcd tv that uses ccfl lamps. The tv is stuck on standby. This is what I have noticed. The standby 5Vs voltage is not 5V but rather 3.28V. There is a 14V rail as well but that measures ok. I put my volt meter on the 5Vs rail and switch on the 220Vac. I noticed that the 5Vs rail goes to 5.1V and quicky changes to 3 28V and steady.
                  I unplugged the main board and ccfl lamp wires and tested the power supply separate from the tv without load and put a 470 ohm resistor to the stby rail to force the tv on.
                  1. Pfc circuit activates and mains smoothing cap is...
                  07-12-2025, 11:44 AM
                • vestaviascott
                  Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                  by vestaviascott
                  Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                  Here's what happens:
                  1) Power on
                  2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                  3) Blue status light flashes for appx 4 minutes...
                  07-29-2020, 06:08 AM
                • AJ847.63e
                  BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                  by AJ847.63e
                  Hi All.
                  Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                  The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                  09-18-2023, 06:42 PM
