Resistor Replacement
  • killian6pk
    • Apr 2010
    • 502
    I am working on a HannStar JC199D and have found (1) 1/8watt 10k ohm resistor that is bad. I don't have any 1/8 watt's in stock so off to RS land. If I can't find this resistor can I use a 1/4 watt in its place? I am not sure of the rules for replacing resistors. This resistor was at the lead end of the 100uf 400v cap which by the way was also bad.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Re: Resistor Replacement
    Yup a 1/4W resistor should be fine if not better than the one installed.
    • killian6pk
      • Apr 2010
      • 502
      Thanks, here's hoping this is the end of the replacements.
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        Need help to replace burned resistor in 350w atx psu
        by mikey5791
        Hi to all forum members,
        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
        12-26-2024, 04:55 AM
      • MidnightRoller
        Can a resistor lose resistance after hot air?
        by MidnightRoller
        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
        02-02-2022, 11:46 PM
      • artvandalai
        What resistor ohm will work better to repair this waterpik?
        by artvandalai
        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
        01-05-2025, 04:10 PM
      • chth96
        Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
        by chth96
        I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
        Since then, This AC/DC adaptor have been out of order.
        But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
        After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
        And Is there any possibility that it will suddenly explode as well as to be out...
        12-03-2023, 04:40 AM
