I just bought a Blue Ring Tester Testing fly back transformer need help with results
    • Jul 2011
    • 6040
    Here are the results of the test
    Pin 1 and Pin 9 <.... I get 3 green lights
    Pin 2 and Pin 8 <.... I get 1 green light
    Pin 3 and Pin 6 <.... I get 2 orange lights
    Pin 4 and Pin 5 <.... I get 2 orange lights
    Pin 1 to Pin 2
    Pin 1 to Pin 8
    Pin 1 to Pin 10 <.... I get no LED lights
    Pin 10 pin 11 pin 12 pin 13 <.... I have N/C
    If there are any other pins that I need to check to know if this part is good or not Please let me know thanks
    • Jul 2011
    • 6040
    Re: I just bought a Blue Ring Tester Testing fly back transformer need help with resu
    Also
    Pin 9 to 10 <.... I get 3 green LEDs lights
    Pin 7 to 9 <....I get 3 green LEDs lights
    Pin 2 to 9 <.... I get 2 green LEDs lights
    Pin 2 to 10 <.... I get 1 orange LED light
    All other pin to pin I get two red LEDs lights
    • killian6pk
      • Apr 2010
      • 502
      Check these two sites.
      https://cdn.badcaps-static.com/pdfs/...f184d5a6d3.pdf This is an in-depth article.
      http://www.anatekcorp.com/ They have a discussion Forum you might check.
      Have you ever stopped to think and then forget to start thinking again?
      As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
      • tony359
        Ring tester
        by tony359
        I'd like to add a ring tester to my toolbox to test flybacks but also low frequency transformers if possible.
        I found a few products online, some based on the "diodegonewild" design, others are different designs. Some are available to build DIY, others are not.
        Any suggestions on a DIY one I could put together? Ideally something which would also be able to test low frequency transformers, that might be handy.
        So far I found these two:
        http://bobparker.net.au/Basic%20Digital%20Ringer/ (the posher version...
        09-13-2023, 07:34 AM
        Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
        by sam_sam_sam
        I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
        One other check that...
        08-03-2021, 06:41 PM
      • mikey5791
        Is it possible for transformer substitution?
        by mikey5791
        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
        My questions are
        1. How do i test to see if the transformer is in good working condition?
        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
        Hope you guys understand what i was asking. My intention is...
        11-03-2022, 02:11 AM
      • dennis_elx33
        3PHASE STEP-DOWN Transformer in Check
        by dennis_elx33
        Hello All,
        i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
        Problem statement: Power tripped Off
        Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
        Action Done:
        1) Replaced the faulty parts with good spare.
        2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
        12-02-2024, 06:52 AM
