My philips 190X LCD monitor power on problem
+ More Options
Posts
  • spanakorizo
    • Oct 2011
    Hello i have this monitor 19'' , 3 years and since last month there were problems to power on. I had to remove the power cable and the put it on again, repeating this process like 10 times and then monitor will power on.
    If i had to close the monitor then i would have to repeat again the same process in order to power on but it would take more time to do the trick.
    Yesterday there a was electricity problem in my flat, so the monitor go off, now it doesnt power on no matter what i do.
    Problem is that the green led light starts, i can see the blue Philips logo for 1 sec and then suddenly restart again.
    This loop happens for ever...1 sec power on,listen the "click" sound and then restart again... what should i do?
    Thank you.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: My philips 190X LCD monitor power on problem
    Originally posted by spanakorizo
    what should i do?
    Take it apart and look for possibly bad caps.
    --- begin sig file ---
    --- end sig file ---
    • spanakorizo
      • Oct 2011
      yeah this i will do tommorow with my flatmate that he has the tools.
      How will i understand if there are damaged caps?
      is it possible to upload a photo and somebody help me?
      Thank you
      • mariushm
        • May 2011
        • 3799
        Yes, read retiredcaps' signature in the post above yours and reply here with your pictures. Click on the Go Advanced button and you'll see a more complex reply form which has a way for you to attach pictures to your comment.
        Faulty capacitors or capacitors that are going out of spec usually have their tops swollen or cracked or there's some liquid/cream going out of them. But this doesn't happen all the time so in some rare cases you need to use digital multimeters or other kind of specialized devices to check if the components are still working right. Some capacitors from particular manufacturers are also known to fail without signs so the more experienced guys here can tell you if that's the case.
        Just post clear pictures and we'll go from there.
        • retiredcaps
          • Apr 2010
          • 9271
          For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
          Here is an example of the pictures we want.
          https://www.badcaps.net/forum/showpo...94&postcount=1
          • spanakorizo
            • Oct 2011
            heeeeello, the capacitors were a little "pumped" so this morning i go straight to my local electronic shop, i replace 5 of them in the power board (all the small) and now is back to life!!!Thank you all, i'm lucky i found this place and fixed my monitor with 1.5 euro!!
            • PlainBill
              • Feb 2009
              • 7034
              This application requires low ESR capacitors. It is likely your local electronics store sold you general purpose caps, which will quickly fail. It would be a good idea to prepare for this - you already know how to replace them so having the proper caps on hand would be a good idea.
              PlainBill
              • mikey5791
                Philips 196V3L monitor power led off
                by mikey5791
                Hi, i was given this lcd monitor last week with the issue of power led blinking. Upon checking the power board, i found 2 pieces electrolytic caps bulged and replaced them.
                Later, when i switched on ac power and detected 5v and 15v dc at output pins. But as soon as i pressed on the front power button, the led on power button lights for 1 second and it turns off.
                So, i tried disconnect the flex ribbon cable from t con board. But all i got is a white screen with nothing on. I suspect there is something short somewhere that prevent the display being turned on. Can someone with...
                01-25-2024, 07:52 PM
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Duranitron
                Asus x512dk rev 2.1 power on problem
                by Duranitron
                When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                11-26-2024, 10:22 PM
              • usbdevice
                Acer X223HQ (Version Bbd) on/off-power-cycling
                by usbdevice
                Hi all
                There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                https://www.badcaps.net/forum/showthread.php?t=50657
                https://www.badcaps.net/forum/showthread.php?t=40512
                The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                It's my dad's old monitor. He...
                08-05-2022, 02:21 AM
              • EazyBone
                LG OLED55C9PUA power problem
                by EazyBone
                Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                The power supply to t con is different story.
                This...
                06-23-2023, 07:43 AM
