Hi Folks……. I think it is a fantastic site and service you have here and I hope you are rewarded with a long and happy life. From reading a few threads and doing a bit of research I think I can say I may have the symptoms of a bad-cap. My 19” Hannstar HU196D monitor began just not coming on straight away and the green light would flash and the speakers would give a short crack sound in unison (the sound speakers often make when you turn a device off) so I assumed the monitor was switching itself on and off because the screen was failing to come on. The problem got progressively worse until it would take several minutes to start. I found if I left the power on and came back later it would start quicker and I put this down to everything and the room warming up a bit. Eventually I was warming it up a little with a fan heater before it would start. Now there are no signs of life at all.
My replacement monitor is a very similar Hanns-g HC194D and it has also started doing the exact same thing, so I'm hoping I can fix at least one of them. I'm a complete novice to this and so I was wondering if anyone could give me a clue as to which capacitors would be the best candidates for replacing first. There are no signs of leakage or bulging on any of the capacitors and it all looks clean and new with no sight or smell that anything has ever been overheated. Could the problem be something other than a capacitor?
On looking for replacements I discovered that not all capacitors are the typical cylindrical shape, so could my problem be something other then the obvious capacitors on the boards? All the cylindrical ones are either Elite or Lelon, except perhaps the great big one as I can't see a name on it. By the way the big one is marked as 400v and so am I right in believing I need to treat it with a bit of respect when it is charged? Should I check it is discharged and how would I do that? A few decades ago before I knew what a capacitor was I got a kick from a TV and I have no desire to be reminded how that felt.
Regards
Brian.
Regards
Brian.
