HG281D Screen flickering on one side
  • Spadje
    • Oct 2011
    Hello there. I am new to the forums and it seems that you all deal a bit with the Hanns G HG281D model. I recently was given this monitor with the knowledge that it was not in working order. When I turn it on the right side of the screen flickers very fast while the left side does nothing. Then the power light turns orange. If I hook it up to a PC I get the right side of my desktop to show but it constantly flickers and nothing ever comes up on the left side. The monitor does not shut off ( even after 1hour of leaving it on) so I doubt it is the power supply. From what I have gathered around the internet I need to replace the logic board. The only thing I can find is this http://www.shopjimmy.com/hannstar-70...-con-board.htm
    Is that all I should need to get it back up and going? I have checked all the caps on the power supply and their is no bulging / leaking caps. Thanks for the help and hopefully I can get it going soon.
    Spadje
  • Rtech
    • Jul 2010
    • 1095
    Re: HG281D Screen flickering on one side
    It may well be the screen itself,so unless you are very very certain it is the Logic Board,I would not be spending money on a replacement.
    • Spadje
      • Oct 2011
      Well that sucks...
      • user56BJLd
        • Jan 2020
        • france
        I repair one monitor simply by changing several capacitors (the one which looks bas, including the big one). I bought them on aliexpress (I first bought first the esr meter also from ali to test the capacitors).
        Surprisingly, it worked (I don't understand electronic)
        • Ado02
          Lenovo Thinkpad X1 Gen 10 - Flickering Screen
          by Ado02
          We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
          The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
          12-16-2024, 02:33 PM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • ravi_1617
          HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
          by ravi_1617
          Hello to all ,
          I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
          Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
          on external VGA port image is perfect /normal , Attached image...
          07-25-2025, 12:07 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • survivalbloke
          HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
          by survivalbloke
          SN: 8CG0213H8W
          ProdID 3C311UA
          This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
          05-08-2025, 12:21 PM
