Your opinion please on lp145w01
  • merkin
    • May 2010
    • 57
    The lcd panel went out on my toshiba A105 laptop. It is definately the lcd driver
    I found this here h++p://www.ebay.com/itm/Toshiba-Satellite-A105-LCD-Screen-LP154W01-Liquid-Behind-Glass-Has-Spots-/160655843057?pt=LH_DefaultDomain_0&hash=item2567d59ef1#ht_18540wt_1210
    Can any experts tell me if this is indeed a water issue and not something with the lcd driver.
    I have replaced CCFL's in many lcd's so this is familair territory.
    My plan is to use the lcd driver and the attached front lcd panel from the ebay item, along with the lcd sleeves and rim and ccfl from my broken lcd.
    My concern is that is not liquid, but something else.
    Does anyone have any idea what else could cause this issue?
    Thanks in advance.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5038
    • New Zealand
    Re: Your opinion please on lp145w01
    Not an expert but it doesn't look like any kind of electrical failure I've heard of.
    The shape of the bad areas does suggest liquid.
    -David VanHorn
    • osrex
      LED DRIVER KEEPS DYING
      by osrex
      Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
      i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
      i have no datasheet at all for the LED lights, all i have is its length.
      long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
      as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
      05-05-2025, 03:36 PM
    • howardc64
      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
      by howardc64
      Problem
      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
      Model & Board Pics
      Conflicting Spec
      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
      https://www.shopjimmy.com/vizio-gj-2k1...
      10-10-2024, 01:16 PM
    • charif
      Audio Driver for Thomson P14C4BK128
      by charif
      Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
      I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
      The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
      Here are the details:
      • Model: Thomson P14C4BK128
      • Operating System: Windows 10 64-bit
      If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
      Thanks in advance for your help!
      04-30-2025, 05:41 PM
    • bohaboha
      how to install gl usb2.0 uvc camera device driver on windows 10
      by bohaboha
      Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
      but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
      any help?
      01-26-2025, 08:33 PM
    • Daveleone
      UN55D6900 BN44-00428B partial led driver circuit failure
      by Daveleone
      Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
      I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
      07-23-2021, 06:31 PM
