Re: HannStar Monitor
You should also check for cold solder joints, there are some LG TV's having vertical lines due to cold solder joints. Maybe your's is a problem similar to those.
HannStar Monitor
I'm still to new at this to give much information, but two things I would check. First I read somewhere that single lines going from top to bottom were connection problems in the tape carrier package which I think is shown in your picture number 5. If that is true I can tell you what I read about the solution to that problem. Also in the power supply why are the pink and white wires glued into the board like that. It makes me think someone broke off the CCFL connectors and this was a patch job. You might check that out on the bottom of the board and see if that is what has happened. I would think that might be a source of your problems also.Leave a comment:
See what some of the other members say, but I think the Samxon GF or on the list.Leave a comment:
The black caps on the video board are Capxon and the green caps on the power board seem to be GFCMD or GF(M).Leave a comment:
Well low and or no voltage going to the panel could mimic an open fuse.
Just because the caps look OK doesn’t always mean they are good.
There are some capacitors that are considered replace on sight.Last edited by alexanna; 10-02-2011, 09:07 AM.Leave a comment:
Whoops, durring start up the screen does show pixel lines darker where the mark is located, the other controls do not change anything except for power switch.Leave a comment:
Theres 2 slight marks about 2" long (that I could live with) as I don't think the pixels are stuck but on the other hand they could be.
I dissasembled the screen and gently cleaned the area with isopropyl and the mark seem to dimish slightly.
Its basic assembled and hooked up to the computer again with no color what so ever just nice and white.
The power switch responds normally although no voltages have been measured, the green and black caps look okay.
I think the problem is on the lcd board simular to previous senario.Leave a comment:
What type of line? Like a colored row of stuck pixels?
What brand are the Blue/Green caps?
Dose the power switch and PLED respond normally?
Have you verified any voltages?Leave a comment:
Found this monitor today at the dump and tried it out, monitor comes on with a line on the screen and then remains white, lamps are working and power supply. Took it apart hoping to find a SMD fuse blown (like before!) but no such luck, this ones a better model I guess since it has digital out put.
I would like to get it going for keeps as its in fair shape if you guys have any ideas. The photos are not so clear in some cases please let me know if I should re-shoot some areas.
Many thanksLeave a comment:
HannStar Monitor
Many thanksTags: None
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by momakaLooking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
When I saw the Craigslist post, I wasn't...-
by sew333My pc:
10850K stock 4800mhz stock Kraken X73 good temps
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming OC
Aorus Z490 Pro Gaming
1 TB SSD
4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
Power... - Loading...
