Benq FP71G+ Backlight (different PCB)
  • dhea1
    • Sep 2011
    • 4
    Nice forum i found on google. Glad to join here.
    I have a problem with my Benq FP71G+ Q7T4, batch date May 2006.
    When i power it up, it's only lite up for 2 second, then off.
    When i plugged it into working computer, the picture only appear 2 seconds also.
    I have different board that already discussed here.
    - power led indicator : OFF.
    what could be the problem?
    the circled components are LR3410
    Best Regards,
    Dee
    • Jul 2011
    • 6046
    Re: Benq FP71G+ Backlight (different PCB)
    Here what I would check is if you have (a ) (or some ) spare CLFs tube laying around and see which outputs
    from the inverter part of the board are working and which one do not and you will have some where to start from
    You ether have a bad CLF tube or a problem with one side of the inverter board
    I would check LR3410 to see if they are shorted that would also be a good place to start as well
    Also look for fuse and see if they are open
    • dhea1
      • Sep 2011
      • 4
      thanks for the prompt reply, Sam.
      I have resolder all of them. Now when plugged into PC, the power led stay green. But no change on the backlight. Still disappear after 2 seconds.
      Is it possible to substitude the LR3410 with ordinary FET (without dumper diode inside?)
      Best Regards,
      Dess
      • PlainBill
        • Feb 2009
        • 7034
        Best Regards,
        Dess
        Not necessary. Those two transistors drive both transformers. If either were bad the backlights would not come on.
        If you have a spare CCFL, or an LCD panel with compatible CCFL connectors, hook that up to this inverter. If the 'test' CCFLs stay on, the problem is not the inverter.
        Another approach is to disconnect the lower pair of CCFLs and see if the backlights come on. Then reconnect the lower pair and disconnect the upper pair, and see if those backlights come on. If one pair does not come on, there is a problem. By swapping connections between upper and lower pairs, you can see if the problem is a transformer or a CCFL.
        PlainBill
        • jetadm123
          • 2169
          The inverter transformers (T801 and T802) are also a problem with this board. With the monitor unplugged and your meter set to resistance, try checking the secondary of each inverter transformer. Looks like the secondary pins are marked 7 and 8 on each transformer. The two readings should not differ by more than 3%.
          Also, are those the original caps on your board? Bad caps can also be the cause of your problem.
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
          • cheebster
            iPad Pro 12.9 5th Gen Backlight Issue
            by cheebster
            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
            Anyone...
            05-20-2025, 09:17 AM
          • canadaboy25
            LG Flatron 24EN33TA No Backlight When Cold
            by canadaboy25
            I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
            I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
            03-07-2023, 12:23 AM
