Benq FP731
  • W1ll
    • Sep 2011
    • 15
    Benq FP731
    My first post and straight in with a question you're all probably thoroughly fed up with but is still a huge b***ache to me.
    It's the very dim screen from start off. I've bought the kit with the fuse and 6 trannies. But still the same. I've re-soldered the t/formers and power trannies. Everything is just the same.
    I'm on the edge of my understanding, but am real good at following instructions.
    Regards,
    Will.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Benq FP731
    Regards,
    Will.
    Define 'very dim'. Do the backlights come on?
    PlainBill
    PlainBill
    • W1ll
      • Sep 2011
      • 15
      Re: Benq FP731
      Very dim as in can just about see what's on the screen with a bright light being shone onto it.
      • PlainBill
        • Feb 2009
        • 7034
        Re: Benq FP731
        OK, no backlights.
        I'm glad you are good at following directions. The first step will be to take two pictures of the power supply / inverter; one of the top, one of the bottom. It is best if they are sharp, well lit, and at least 1000 x 1000 pixels. Try to take them in natural light (no flash) from directly above the board. Attach the pictures using 'Manage Attachments' - above the text entry area.
        PlainBill
        • W1ll
          • Sep 2011
          • 15
          Re: Benq FP731
          Here are the images as requested.
          • PlainBill
            • Feb 2009
            • 7034
            Re: Benq FP731
            Thanks. I'm going to have to revise my estimation of the quality of pictures possible. These are excellent.
            If you look at both top and bottom views you will see a pair of lines running across the board. This designation is arbitrary, but I will refer to everything above those lines as the power supply area, everything below as the inverter area.
            Straddling the boundary is PF751. Use either of the two lower heat sinks on the left side of the power supply area as ground. What are the voltages at the upper and lower ends of PF751?
            Next, in the upper right corner of the power supply is the connector to the signal card. The two right hand pins on that connector are the brightness and On/Off control lines. What are the voltages on those pins?
            Last, the lime green caps. What is the brand and series of those caps?
            PlainBill
            • PlainBill
              • Feb 2009
              • 7034
              Re: Benq FP731
              Argh!!! Test 2 refers to the picture of the bottom of the power supply board. The other two refer to the picture of the top.
              PlainBill
              • W1ll
                • Sep 2011
                • 15
                Re: Benq FP731
                There is 36.8V on the power supply side of the fuse, 0V on the inverter side.
                0.04V on the first lead (black).
                3.8V on the second lead (brown).
                Caps are Lelon A410(M) A419(M)
                • PlainBill
                  • Feb 2009
                  • 7034
                  Re: Benq FP731
                  That confirms - the fuse is open.
                  I've marked up a picture. Set your DMM to the 200 ohms range.
                  Perform the following tests on the transistors circled in yellow (note that each lead has a letter next to it).
                  1. Black probe to B; red probe to C
                  2. Black probe to B; red probe to E
                  3. Black probe to C; red probe to E
                  All of these should show open.
                  Perform the following tests on the transistors circled in orange (note that the leads have no identification, so letter them S, D, G, starting with the leg closest to the top of the picture).
                  1. Black probe to S; red probe to D
                  2. Black probe to S; red probe to G
                  3. Black probe to D; red probe to G
                  These should also show open.
                  If all of the above show open, measure the resistance from the lead circled in red to the lead circled in black.
                  PlainBill
                  • W1ll
                    • Sep 2011
                    • 15
                    Re: Benq FP731
                    These 6 components plus the fuse have all been renewed.
                    All tests show as being open.
                    No reading from the fuse to diode either.
                    Items marked in orange were CHN D10PF 06 31W417, but were replaced with FU9024N.
                    Told these were compatible.
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Re: Benq FP731
                      The service manual shows FU9024N, so that should not be a problem.
                      Since the fuse is open, there are a couple of options.
                      1. Assume you overheated it when you soldered it in and it went open. I don't like assuming that.
                      2. Rig a current limiting jumper across the fuse. My favorite is an 1157 (dual filament 2.1 /.6 A @12V) automotive taillight (I'm not sure what the European equivalent is). If the light glows at full brightness with the fiilaments in parallel, there is definitely a problem.
                      3. Buy a pigtail fuse holder and some fuses, solder the leads in place of the picofuse and try again.
                      I recommend the light bulb. If it glows brightly, remove one FU9024N and retest. If the light still glows brightly, you have a problem on that part of the inverter. If the backlights come on for two seconds, you know the side with the FU9024N is good.
                      PlainBill
                      • alexanna
                        • Mar 2010
                        • 1346
                        Re: Benq FP731
                        I am not sure about the compatibility of the transistors.
                        When you installed the kit, did the backlights work for a while or did the fuse go open immediately?
                        • W1ll
                          • Sep 2011
                          • 15
                          Re: Benq FP731
                          After testing the bulb does glow brightly at first for a couple of seconds then goes out followed by one brief flash, then nothing.
                          I will remove 1 mosfet FU9024N, but is there a test I can do with my DMM?
                          Not sure about these little beauties.
                          • W1ll
                            • Sep 2011
                            • 15
                            Re: Benq FP731
                            After removing both FU9024N. One at a time and retesting.
                            The bulb lights for 2 seconds when the middle one is removed but doesn't light when the one near the edge of the board is removed.
                            Are we getting any nearer to solving this?
                            • alexanna
                              • Mar 2010
                              • 1346
                              Re: Benq FP731
                              Is Q 743 installed correctly? Looks like it's reversed
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Re: Benq FP731
                                Yes. First of all, having an intelligent assistant doing the actual work is a big help. The results show that something different is happening on the two sections. One possibility is one is operating normally, but has no load, so it draws very little current; while the other has a fault that causes it to draw full current. The other possibility is one is operating normally and lighting a CCFL while the other isn't even working.
                                Now for some questions - Did you have the CCFLs hooked up when you did this test? Did they light up? What is the current rating of the lamp you are using?
                                Here is the problem. The best way to do this testing is with a current limited bench supply. Even an inexpensive one is too expensive for the casual user. It might be possible to use a DMM set on the current range, but if the fuse in the DMM blows you haven't saved any money. My DMM has a limit of .2A on the fused current range; using a higher range MIGHT damage the DMM. That isn't doing you any favors either.
                                PlainBill
                                • W1ll
                                  • Sep 2011
                                  • 15
                                  Re: Benq FP731
                                  Although I hate to agree with you, I think Q743 was reversed when the picture was taken!
                                  Both FET's aren't in the board at present, due to the latest tests from PlainBill.
                                  I think I'll start over again from scratch with the advice given.
                                  • W1ll
                                    • Sep 2011
                                    • 15
                                    Re: Benq FP731
                                    Both CCFL's were hooked up during the test and they both lit up along with the auto bulb that I used to bridge the fuse.
                                    It's rated at 21W/5W. (Stop & tail), between 0.5A & 2.4A.
                                    Only the lower rated filament - 5W would light.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Re: Benq FP731
                                      That is excellent information. The reason the higher wattage filament wouldn't light is the current draw of the inverter was too low. It may be a combination of an open fuse and the reversed FET. I can't visualize the consequences of the reversed FET well enough to say if that would have blown the fuse, however.
                                      PlainBill
                                      • W1ll
                                        • Sep 2011
                                        • 15
                                        Re: Benq FP731
                                        The Fet's were correctly fitted when I conducted your latest tests.
                                        I'm still left with exactly the same problem though, 2 seconds to lights out.
                                        If I have to remove them again I think the tracks are going to break up.
                                        • seppde
                                          Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                          by seppde
                                          I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                          ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                          The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                          In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                          02-09-2024, 05:19 AM
                                        • AJ847.63e
                                          BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                          by AJ847.63e
                                          Hi All.
                                          Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                          The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                          09-18-2023, 06:42 PM
                                        • ChatBTC
                                          Benq EX3501R
                                          by ChatBTC
                                          Hi!
                                          I am new to this site, and found it via LLM ChatGPT.
                                          I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                                          01-24-2025, 08:49 PM
                                          BenQ JoyBook S52 S53 Laptop Schematic
                                          Quanta ED3...
                                          11-01-2024, 02:03 PM
                                          BenQ S72 Laptop Schematic
                                          Inventec Grasshopper Rev 3.0...
                                          11-01-2024, 07:23 AM
