Benq FP731
  • W1ll
    • Sep 2011
    • 15
    Re: Benq FP731
    I am no nearer solving this problem now than I was a week ago!
    Everything listed so far has been done, but still the 2 secs to dark persists.
    My question is how should I progress from here?
    Will.
    • PlainBill
      • Feb 2009
      • 7034
      Re: Benq FP731
      Will.
      Try hooking up a known good set of CCFLs, if you haven't done so.
      The problem COULD be in the sense circuitry; I don't even want to go there.
      PlainBill
      • W1ll
        • Sep 2011
        • 15
        Re: Benq FP731
        I don't have any Parts that I can swap.
        The lamps work, although briefly. How could it be both of them at fault?
        • alexanna
          • Mar 2010
          • 1346
          Re: Benq FP731
          Are you using a fuse for the inverter,or do you still have the 1157 bulb installed?
          • W1ll
            • Sep 2011
            • 15
            Re: Benq FP731
            I'm still using the bulb as I haven't ordered a replacement fuse yet.
            I'm waiting to see if I need to purchase anything else.
            • alexanna
              • Mar 2010
              • 1346
              #26
              Re: Benq FP731
              I have not tried using the light bulb as a simulated load,but I wonder if the light bulb may be reducing the available voltage to the inverter causing the 2 sec problem now.
              If it were me I would try a fuse and see what happens.
              • W1ll
                • Sep 2011
                • 15
                #27
                Re: Benq FP731
                I've substituted the bulb with a domestic 3A fuse.
                This time the lights only come on once instead of twice and then go out.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Re: Benq FP731
                  If you disconnect all but one CCFL will it light for a few seconds? Try this with all four CCFLs.
                  The design of the inverter is such that any one bad CCFL will cause all to shut down.
                  PlainBill
                  • W1ll
                    • Sep 2011
                    • 15
                    #29
                    Re: Benq FP731
                    I think it's time for a new monitor!
                    In attempting to gain access to the lamps, one of the ten ribbon cables to the screen tore away!
                    Even though I was especially careful as I knew they were delicate, to my disbelief it still happened.
                    I would therefore like to thank PlainBill & alexanna for their help.
                    Maybe next time I'll do better.
                    Regards,
                    W1ll.
                    • seppde
                      Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                      by seppde
                      I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                      ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                      The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                      In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                      02-09-2024, 05:19 AM
                    • AJ847.63e
                      BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                      by AJ847.63e
                      Hi All.
                      Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                      The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                      09-18-2023, 06:42 PM
                    • ChatBTC
                      Benq EX3501R
                      by ChatBTC
                      Hi!
                      I am new to this site, and found it via LLM ChatGPT.
                      I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                      01-24-2025, 08:49 PM
                      BenQ JoyBook S52 S53 Laptop Schematic
                      Quanta ED3...
                      11-01-2024, 02:03 PM
                      BenQ S72 Laptop Schematic
                      Inventec Grasshopper Rev 3.0...
                      11-01-2024, 07:23 AM
