Lien Chang Co > Li-2070 Rev A02 < Invertor board
    • Jul 2011
    • 6018
    Bn44-0073
    Need a Tranformer T2 # on the Tranformer 010NJ14G
    Google search lead nothing
    Can any one help Thanks
    master hoarder
    • May 2008
    • 12164
    • Bulgaria
    Re: Lien Chang Co &gt; Li-2070 Rev A02 &lt; Invertor board
    I don't know about the transformer, but I see a cap marked with "GF" - most likely Samxon GF. Those are known bad series from Samxon. I would suggest you replace that first and see what happens from there. Samxon GF are entry-level low ESR, so anything like Panasonic FC, Nichicon PW and PM, and United Chemicon LXY and LXZ will work. Nichicon HE and United Chemicon KY will more than likely work too.
      • Jul 2011
      • 6018
      momaka
      Thanks for your reply
      I will not replace any caps on this board until I can find a transformer one of them you can see a burnt mark on the side of it......it's so bad that the board below it has a black mark on it where it had gotten real hot once
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
