T240 Monitor Backlighting Issue
+ More Options
Posts
  • johanneszab
    • Feb 2013
    Re: T240 Monitor Backlighting Issue
    I also wanted to say thanks for the contribution to this thread. It saved my T240HD which suffered on the TSTB symptoms. I've changed this capacitor and now it works like on its first day:
    http://www.jzab.de/stuff/t240hd/kapu...ator_small.jpg
    One different thing I wanted to ask is, what do you think of these wired substances on the other, system PCB i've noticed:
    I've taken two images:
    http://www.jzab.de/stuff/t240hd/board/board.jpg
    Here on the left edge, it looks like the board corrodes and on the whole board surface, there is a sticky, orange fluid on it, looks like coke :P. I wonder where this comes from, and if i should remove it? I certainly never spilled any liquid over my TFT and because of the large amount, i think it was in there right from the beginning. It's only on that board, not on the other one though. The TFT is already 5 years old and worked till last week, so i though ignore the substances on it.
    Here is an other picture: http://www.jzab.de/stuff/t240hd/board/board2.jpg
    What do you think is that, just out of curiosity?
    • g40rocket
      • Feb 2013
      • 5
      • Portugal
      #42
      Hey fellows,
      Sorry the delay.
      I finally discovered my problem, it was the bulb, check the photo:
      Is there any way to get this replacements or i have to buy a new backlight or panel ?
      Thanks in advanced.
      • g40rocket
        • Feb 2013
        • 5
        • Portugal
        #43
        A little update, i finally purchased my new CCFL tubes from http://www.ccflwarehouse.com
        The Samsung T240HD is already in good working order.
        Thanks to all that help me in this forum.
        With 38 usd (including shipping) i fixed my LCD again !
        • AndrakondrA
          • May 2013
          • Israel
          #44
          After TSTB syndrome, replaced capacitors, ccfl lamps, (transformer (0.9K 1.0K secondary), still have a problem...
          I decided to convert my LCD to LED, so want to disconnect the high voltage part of the board (don't want this part to consume electricity)
          Questions:
          -Can I totally disconnect high voltage part of the board and how?
          - Is there any possibility to use monitor power supply to get 12v for the leds or must use independent power supply with independent switch?
          Thanks in advance!
          • amt
            • Apr 2014
            • 4
            Well Mine is fixed! I was on it the other day and one corner went black then with in 1 minute the hole thing was black. I could see that there was something on the screen but it was black. I opened the case and found a resistor with the board burnt around it, the inverter with a small melted spot on the top and the board burnt and the board starting to burn by the transistor on the back. I took off the inverter and could not find anywhere I could get a measurement and tried to open the case to see the connections inside. Luckily I wrote down the number first as it just kind of fell apart under force. I replaced it and bought caps for the ones next to it as I was sure they got pretty hot. They must of been cheap caps (the new ones)as they measured 950 each where the old ones were 820 and that is what they measured (No esr meter). Like I said, I replaced the inverter and the 2 caps and all is well again. Thanks for all of you that input into this topic as it let me learn how to fix this.
            Thanks again.
            • lizzrd
              • Jun 2014
              • 21
              After reading about the OP first post about screen blacking out, and disassembling, seems my board is a bit different. I am looking to check the transformer as shown in reply #4+5.
              Any help on what solder points to check for resistance would be greatly appreciated...
              • selldoor
                Slow Learner
                • 7870
                #47
                We prefer pictures to be posted using manage attachments so they remain on the thread
                can you edit your post to remove and re attach
                • lizzrd
                  • Jun 2014
                  • 21
                  sorry for that... i do not have a edit option.
                    1 & 2, 3 & 4.
                    BTW, the solder joints of the transformer legs do not look good, You my want to inspect the whole board.
                    • lizzrd
                      • Jun 2014
                      • 21
                      I am a total beginner. 1+2 , 3+4 is what i thought was to be checked. But the board being different puzzled me, still does. Why would they be different ? Would you tell me what looks bad about those 4 points ? I only have a multi-meter, how/what could i check for the whole board ? I could take this board to a PC repair place that did some solder work for me last month if i am not 'able' to. sorry for all the questions...
                        Oops, set your meter to 2K Ohm scale and take the reading between pin 1 and 2, then pin 3 and 4. NO POWER to the unit of course. The solder joints look like they have some ring (hair line crack) around the pins.
                        For examples:
                        http://s807.photobucket.com/user/bud...?sort=3&page=1
                        • lizzrd
                          • Jun 2014
                          • 21
                          so the black to pin 1 and red to pin 2 , shows it reading up to 1. and the same for 3+4...
                          i also looked at the solder with a mag glass and they seem ok , like the other solder points.
                          I do not see any discolored points or bad caps.
                            What scale do you set the Meter's Ohm mode to, 2K?
                            • lizzrd
                              • Jun 2014
                              • 21
                              yes , sorry for the timing of my posts , i have 3 kids here, so kept busy...
                                Can you post the pictures of the top side of the board and the P/N as printed on the transformer so we can look for the pin out of the transformer?
                                • lizzrd
                                  • Jun 2014
                                  • 21
                                  thanks for your reply Bud,
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #57
                                    Try the test again resistance should be around 1000ohms
                                    Check you have the meter selector in the correct position - it goes all the way round on mine so
                                    200ohms look pretty much the same as VAC600
                                    Also try scratching the top of the solder joint with the probe
                                      The pin out of the windings in my post 49 is correct, so you may have to clean of the flux or resolder the pins of the transformer and try reading the resistance again.
                                      It has the same pin out as this one:
                                      http://s807.photobucket.com/user/bud...tml?sort=3&o=3
                                      • lizzrd
                                        • Jun 2014
                                        • 21
                                        I scraped on the side of the pins and kind of pushed the points of the probes in a bit.
                                        Got readings of 1.006 and 1.012. Don't know if it matters, this board is disconnected from the other board of the unit.
                                          1.006 K ohms, and 1012 K Ohms? If they are, then they are good.
