Acer X241W (Power Board Failure)
  • stevekasian
    replied
    Re: Acer X241W (Power Board Failure)
    I know it's the connector to the inverter! :-p But everyone always says that the inverter only gets 12V or more. So the control lines are on the 5v lead?
    And what is the "signal card"?
    SK
  • PlainBill
    replied
    Originally posted by stevekasian
    Yes. All fuses are good. All transformers read the same (chances are slim all 12 went out simultaneously).
    As for voltages on the 19v rail being a problem, I could be mistaken but I don't understand what 5v would be doing on this rail. ?
    Because, Doofus, that is the connector to the inverter. It carries ground, the 19V inverter supply and the inverter control lines - On/Off and Brightness.
    Those voltages may indicate a problem with the signal card, or with the inverter.
    PlainBill
  • stevekasian
    replied
  • jetadm123
    replied
    Have you tried checking the fuses on the inverter board?
  • stevekasian
    replied
    CNS1 is not an issue, as the only problem is the backlight not coming on.
    The voltages on CNS2, however, are. Please see photo #3 (annotated) for voltage readings there.
    All fuses are good.
    Thanks,
    SK
  • alexanna
    replied
    What voltages do you see on CNS1?And is FS3 a fuse and dose it test good?
  • stevekasian
    replied
    Ok, I changed out all the caps listed previously and still no dice. Anybody?
    Thanks,
    SK
  • stevekasian
    replied
    The 12v rectifier checks ok out of circuit.
    I did notice that 2 of the largest caps in the images above (19v section) were most likely replaced by a previous tech and are slightly too tall. As a result, the head skink "cap" that goes across all 3 sections put a lot of pressure on them when screwed into place, and it appears that one may have crumpled a bit under the stress. So I've ordered replacements for all the remaining OEM caps, as referenced in a previous post, plus all 3 of the largest caps (680uf@25V) in a shorter/smaller can.
    So it looks like the middle of next week I should know whether or not this did the trick!
    SK
  • dondrusco
    replied
    Try to start with this post in another thread - AL2423W has the same power board
    https://www.badcaps.net/forum/showpo...9&postcount=23
  • stevekasian
    replied
    Ok, as a follow up, I have checked the 12v rectifier in circuit and found it to be conducting equally in all directions from P-N/N-P. I'm gonna remove it from the circuit tomorrow and check it again, but I believe that's a bad sign, especially considering it's the 12v pin on the rail that is registering no voltage.
    I believe I should also order the caps circled in PlainBills annotated image in the other thread, as they are apparently the only ones that look to be original equipment on this board. I will give an update here tomorrow... Time for sleeeeeep.
    SK
  • stevekasian
    started a topic Acer X241W (Power Board Failure)
    I have an Acer X241W with a backlight failing to come on.
    Display works - I can see the OSD Menu when holding a flashlight to the screen, and it is responsive to menu/button controls.
    Upon opening up the unit, I could tell it has been worked on. Replacement low ESR caps have been installed on both the power and logic boards, and the work looks good.
    I pulled the inverter board and checked the transformers. They all appear to be in working order. No burns or heat marks visible and each measures the same resistance across each lead in each respective combination.
    So I decided to power up the power board (Model AS08B360411) and take some readings from the 5v/12v/19v rail that powers the inverter. When switching the unit on and measuring voltages before the standby mode engages, this is what I came up with (see attached images and annotation on image #3).
    There does appear to be heat discoloration on the front and back of the section of the board I'm dealing with, although I believe it is probably from an earlier failure, as no components appear to be damaged/burned.
    Anyone care to help me troubleshoot this board?
    Thanks,
    SK
    p.s. Entry #17 on the following page reports almost the same readings on the pins of a similar monitor: https://www.badcaps.net/forum/showth...ighlight=x241w
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • Roman555
    [Offer] Acer IPIMB-AR (w/o on-board gfx) of Acer Predator G5920 fullflash BIOS
    by Roman555
    I'd like to offer an Acer IPIMB-AR Rev: 1.02A fullflash BIOS (cleaned ME region). The model is for Acer Predator G5920.
    It is a model that is based on Intel Z77 PCH and doesn't have on-board graphics and video connectors.
    I suppose it doesn't have any restriction about discrete graphics cards (I mean they don't have to be in a whitelist).
    Please don't mistake this mainboard with a similar model with on-board graphics and based on Intel B75 PCH.
    Jumper FLASH_OVERRIDE
    default position: 1-2 - BIOS area protected
    position 2-3 allows to dump BIOS or write
    06-26-2025, 05:15 AM
  • delpiero3
    Sony Vaio SVS MBX-261 board failure
    by delpiero3
    Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
    Nevertheless, let's say, i don't come as a total beginner.
    I have this old laptop, which suit perfectly my needs, with the...
    10-29-2024, 06:16 AM
