BenQ FP731S No screen at all!
  • Icitte
    • Aug 2011
    • 61
    I've got a BenQ FP731s that doesn't come up. Only green light. Not even the BENQ flash screen, nothing. Open it to see if there is any bad caps; nothing. Check the Fuse (2ah 250v) it's good.
    I'm a noob and I need help!
  • smason
    • 1652
    Re: BenQ FP731S No screen at all!
    The FP731 are famous for bad solder joints on the inverter transformers, this leads to shorted transistors and a blown picofuse.
    You will need to test the transistors in the inverter section, as well as the picofuse.
    • Icitte
      • Aug 2011
      • 61
      is it something we can "visually see"?
      • smason
        • 1652
        No, you'll need to measure with a meter.
        • Icitte
          • Aug 2011
          • 61
          anybody have a website to know HOW to test electronic item, onboard and offboard!
          I would appréciate. Thanks. Now google time.
          • jetadm123
            • 2169
            Try checking out YouTube. There are many videos posted on how to use a meter to check various components.
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
            • spice_disc
              Vizio TV M50-C1 reboot cycle and static on screen
              by spice_disc
              I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
              The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
              09-08-2024, 02:37 PM
