Re: Samsung 2493 HM issue
I have:
+24v:1.2v
Gnd: 0v
SOS:0.13v
BL:0.13v
Adim:0.06v
It would be best to have everything connected,Please be careful not to short anything to ground.Leave a comment:
Hi Alexanna,
Thanks for your quick reply, on the left hand side connector there are pins labelled +24v, Gnd, SOS, BL, A_DIM.
Do I have to plug all the cards together to measure these voltages ?Leave a comment:
I do see 2 Caps that looked bulged.
On the left side of the power supply there is a connector, I can read that some pin are 24Volts,There should be some pins labeled on/off or p/on and one that is marked dim,and some grounds.
With a signal going to the monitor what voltages do you read on these pins?Leave a comment:
I Just discovered that forum a couple days ago and there seems to be very knowledgeable people and a lots of information here !
I have a Samsung syncmaster 2493HM which was working fine until a few days ago, then suddenly the backlight started to go dim and a few seconds later, the monitor was black.
Now, when I turn on the monitor, the blue LED light comes on and stays on solid, never go to sleep (never amber or blinking) and the screen remains blank. Even with a flashlight I don't see any walpaper.
I looked at some similar post in the forum and didn't find any solution yet. I am very new at this.
I didn't find any obvious damaged caps, the fuses seems to be good, I checked the 2 voltage regulators on the logic board as per this thread
https://www.badcaps.net/forum/showth...ghlight=2493hmand I find the same results as Werthles:
"On the red circled chip i got 5.22, 0, 5.22 on the three pins starting from the top in the image. On the yellow circled chip i got 2.52, 0, 3.31 on the three pins starting from the top in the image."
Attached are pics from my different boards.
Can somebody help me please ??Tags: None
by KjellAfter installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...08-01-2025, 09:15 AM -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by NairolfHello,
I have a Samsung DM32D display.
When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
Here’s what I have tried so far:- Disconnected the cable between the mainboard and the power supply → the backlight turns on.
- Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
- Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
From these tests, I suspect the problem might be on the mainboard. Could anyone...3 Photos08-24-2025, 03:47 AM -
by vincentedelHello,
I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...-
by ManucslHello.
My TV is a QE65Q800TATXXC Samsung TV.
Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
Any ideas to check would be very appreciated 😊
After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump... - Loading...
