Samsung 2493 HM issue
  • zulururu
    replied
    Re: Samsung 2493 HM issue
    Thank you Plainbill, I will measure that, also my DMM doesn't have capacitance function, I discovered I have one at work I can use which has capacitance function, should I use that one instead ? If yes, to measure capacitance, should I desolder CM812 or there is no need for it ??
  • PlainBill
    replied
    Originally posted by zulururu
    After more than a month, I've finally received my SMPS controller ... but after installation, unfortunately, my monitor is still not working .... I still don't have 5.3v or 24v ....
    Do you have anymore suggestion ?
    Darn!!! I had temporary access to another BN44-00195A and made some measurements with the supply operating. Here is the comparison. As you can see, they are very similar. Unfortunately, I did not make measurements on other points on the board, and no longer have access to that supply.
    Pin Yours Other one
    1: 5.05v / 5.08V
    2: 5.05v / 5.08V
    3: 2.54v / 2.55V
    4: 0.00v / 0.00V
    5: 5.08v / 5.11V
    6: 0.07v / 0.07V
    7: 0.07v / 0.07V
    8: 5.04v / 5.08V
    9: 14.60v / 11.90V
    10: 0.00v / 0.00V
    11: 0.19v / 0.19V
    12: 14.06v / 11.30V
    13: 0.00v / 0.00V
    14: 0.27v / 0.25V
    15: 15.06v /12.2V
    16: 5.04v / 5.07V
    The next thing to test is CM812. I know your DMM does not have a capacitance function, so pull CM812, set your DMM to the 20 Megohm range, and touch the probes to the cap. You should get a reading that increases, eventually going open.
    PlainBill
  • zulururu
    replied
  • zulururu
    replied
    Ah ok Thanks Alexanna !
    I ordered an SMPS controller on August 19th apparently, it's coming from Australia and I still did not receive it, so as soon as I install it, I will let you know if that worked, if not, I will try to check that capacitor !
    Thanks for the heads up though !
    Cheers,
  • alexanna
    replied
    Is it a question for me ?? if yes, my DMM doesn't have a capacitor range .....sorry !
    Not exactly, I got the threads mixed up.
    I am not really sure where you are on you monitor, I guess the point I was trying to make was there have been several failures of that capacitor. It sure wouldn't hurt to check the capacitance of it, and if the equipment on hand is unable to test it, I tried to give several suggestions on how to get it tested without spending a lot of money.
  • zulururu
    replied
  • alexanna
    replied
    The monitor I had where that capacitor failed was the BN44-0173 Board, there was no obvious bloating or burning on the outside of the cap. After removal from the board there was some very slight discoloration of one of the pins where it went into the plastic, it was very hard to see.
    If your meter does not have a capacitance reading ability, and buying a new meter is out of the question.
    There would be nothing wrong with having someone checking it for you, any heating air condition technician, or if you have small local hardware store ask them to help you out, I would suspect the cost to be minimal if any.
  • PlainBill
    replied
    On mine it's written on the top:
    12 NJ 630v
    some kind of a reversed "C" 4 MMKP
    On the side of it I can read:
    PILKOR
    WK0747
    I hope this help !
    Yes, it does. Thank you. Pilkor is the manufacturer, it's a 12nF, 630V, 5% cap.
    Now, the $64 question: Does your DMM have a capacitance range? This cap has an equivalent in the BN44-0173A power supply, and is known to fail.
    PlainBill
  • zulururu
    replied
    12 NJ 630v
    PILKOR
    WK0747
    I hope this help !
  • PlainBill
    replied
    Hello all,
    Just to let you know that I still didn't receive my SMPS controller, so taht's why I didn't update that post yet ! It should arrive soon hopefully !
    Thanks for the information. We're waiting to find out if that will fix it.
    On a related subject, what is printed on the cap labeled 'Long Blue Cap' in the attached picture?
    PlainBill
  • zulururu
    replied
    Hello all,
  • PlainBill
    replied
    Originally posted by pamr4
    Analogy with common power supply failure like 245BW. (when you don't figure it out, excalate the problem, search document findings, etc.
    You were referring to the BN44-0173A power supply. This is a BN44-00195A supply. The standby SMPS controller in the BN44-0173A derives startup power through a series of resistors. The standby SMPS controller in the BN44-00195A is an integrated design, and is connected directly to the rectified mains voltage; it derives startup power internally. What is more, it is working, and the main SMPS controller is receiving power.
    PlainBill
  • pamr4
    replied
    'De Nada.'
    Now could you explain what you were referring to in your post #45? I've been going round and round these supplies, and between the lack of a schematic, obscured traces, inadequate test gear, and obtuse datasheets, it's been difficult to figure out where the actual failure lies.
    PlainBill
  • PlainBill
    replied
    Sorry for missing that PlainBill.
    'De Nada.'
    PlainBill
  • pamr4
    replied
  • PlainBill
    replied
    Please confirm that the big cap is 82micro. If it is, measure the voltage across the legs of the cap (10 sec) and post reading.
    Already done. Note the results in post 21.
    PlainBill
  • pamr4
    replied
  • zulururu
    replied
    Excellent ! I just ordered it for 5.8USD postage include !
    I will let you know if that fixed it !
    Thanks you again !
    Gilles
  • PlainBill
    replied
    I shorted my DMM probe and I read 0.4 ohm but I realised I made a mistake when I gave you some value of 4 ohms, it was a misreading and was actually 0.4 ohm ! Sorry about that !
    I measured all the resistors around the big capacitor, here are the results:
    RB801 reading 100060 OHMS vs colour code 10*10000 +/-5% OK
    RB802 reading 97600 OHMS vs colour code 10*10000 +/-5% ok
    RM801s reading 32.7 OHMS vs colour code 330 /10 ok
    RM801 reading 0.6 OHMS vs colour code 228*0.1 problem ?
    RB808 reading 2.4 OHMS vs colour code 2OHMS OK
    RB803 reading 47.4 OHMS vs colour code 47 OHMS OK
    Do you think the problem I have with RM801 is ue to my cheap DMM ?
    My goal if possible is to find the exact faulty component so I guess I will order a MP33067P, I found one here:
    http://www.futurlec.com/cgi-bin/sear...earch=MC33067P
    for 2$ + 4$ shipping, can you confirm that's the right one ??
    If yes, I will order it, the shipping will take 2 weeks !!
    Thanks you all for your help
    That's the one. Congratulations on finding it at a very reasonable price.
    PlainBill
  • zulururu
    replied
  • Kjell
    Samsung Series 9 - BIOS issue
    by Kjell
    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
    08-01-2025, 09:15 AM
    09-07-2024, 05:50 AM
  • Nairolf
    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
    by Nairolf
    I have a Samsung DM32D display.
    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
    Here’s what I have tried so far:
    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
    From these tests, I suspect the problem might be on the mainboard. Could anyone...
    08-24-2025, 03:47 AM
  • vincentedel
    Samsung SyncMaster 740n Phase Control Issue
    by vincentedel
    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
    04-22-2025, 12:33 AM
  • Manucsl
    QE65Q800TATXXC Samsung TV Issue
    by Manucsl
    Hello.
    My TV is a QE65Q800TATXXC Samsung TV.
    Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
    Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
    Any ideas to check would be very appreciated 😊
    After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
    02-19-2025, 07:47 AM
