Samsung 2493 HM issue
  • zulururu
    replied
    Re: Samsung 2493 HM issue
    Here are some more pictures !!
    I wil do the voltage measurements in a few minutes !
    Just in case you're wondering the 16 pins IC (ICM801) has a number on it :
    MC33067p
    CPDT0744G
  • PlainBill
    replied
    Originally posted by zulururu
    Thank you all for your help ..... do you have any idea on how to do that ?? I'm really new at this !!
    I will need a picture of the bottom side of the power supply. the picture of the top is excellent, something equivalent of the bottom would be helpful.
    Also, ICM801? (the 16 pin IC) is the SMPS controller for the main supply. Pin 1 is in the upper left corner, and pins are numbered counterclockwise. Pin 4 is Gnd, I am interested in the voltages on pins 5, 9, and 15.
    PlainBill
  • zulururu
    replied
  • PlainBill
    replied
    OK, I did some measurements as per
    https://www.badcaps.net/forum/showthread.php?t=15796
    Post number 9 by Plainbill and I have a different results:
    With monitor turned On
    Between pin 3 and 1: 0.02v
    Between pin 3 and 2: 16.4v
    Between pin 3 and 4: 1.08v
    Between pin 3 and 5: 378V
    With monitor turned Off
    Between pin 3 and 1: 0v
    Between pin 3 and 2: 14.88v
    Between pin 3 and 4: 0.67v
    Between pin 3 and 5: 160V
    Any idea on what it means ??
    Pin 1 is OCP (Over Current Protect). The change in voltage indicates the standby power supply is putting out more current.
    Pin 2 is Vcc.
    Pin 4 is the feedback (Indicates if the power supply output voltage is too low or too high).
    Pin 5 is the startup voltage. The change in voltage indicates the PFC front end is working.
    All of these readings indicate the standby SMPS, and the standby processor are working properly, and the signal to turn on the main power supply is being received by the power supply. Now it's time to troubleshoot the main supply.
    PlainBill
  • zulururu
    replied
  • zulururu
    replied
    The input connector labelled Micom is labelled S_B on the output connector of the power supply and yes I have 5.21V on that one
  • alexanna
    replied
    I could possibaly be wrong, but i think the pin Micom is the standby voltage?
  • jetadm123
    replied
    In the link that alexanna provided, post #6, one of the pins on the connector is labeled S_B. I believe this is the standby voltage. It should read approx. 5V. Are you at least reading that?
  • zulururu
    replied
    Thanks for the link !
    I'll try to do some more troubleshooting
  • alexanna
    replied
    Well, I have 3.2v on the Power en when the monitor in turned On, and 0v on the power EN when the monitor is turned off.
    Maybe my last post is not really clear:
    Power EN:3.22v/0v means monitor On:3.22v, monitor Off:0v
    Thats a good thing,There is another thread tats describes you problem with some more things to test.If you can't find it i will try to add a link
  • zulururu
    replied
  • dumpystig
    replied
    Hmm... that board really is dead
  • alexanna
    replied
    The Power EN 3.2V is missing,that is what will request the 5.3V and 24 V. to turn on
    at this point I am not sure why its missing
  • zulururu
    replied
    Here is the measurements I did on the connectors going to the logic board:
    With the monitor switched ON/Switched Off:
    24v Det: 0.12v/0.01v
    pwm dim: 0.06v/0v
    Brt_ctl:0.06v/0v
    A_dim:0.13v/0v
    Bl_en:0.11v/0v
    NC:0v/0v
    NC:0v/0v
    5.3v:0.26v/0v
    5.3v:0.26v/0v
    GND:0/0v
    GND:0/0v
    GND:0/0v
    +18v:0v/0v
    +18v:0v/0v
    +18v:0/0v
    GND:0v/0v
    GND:0v/0v
    GND:0v/0v
    +5v Micom: 5.21v/5.21v
    Power EN:3.22v/0v
  • alexanna
    replied
    Should I leave the logic board unplug for the measurement ? I will check that tomorrow and let you know...
    As I recall the 2 caps top seems flat view from the side.
    Thanks again !
    Every thing hooked up
  • zulururu
    replied
    Thanks again !
  • alexanna
    replied
    Apparently this Power supply is also used on the samsung 245BW and 245B...
    http://cgi.ebay.com/Samsung-2493HM-2...-/170619669136
    That's what I thought.
    There are 3 threads open on this P/S now.
    On the connector going to the logic board, there should be a p/s on and a 5.3v. Pins
    I don't know for sure if 24v is on that connector but if it is measure it.
    What voltages do you measure?
    Do the 2 capacitors near that connector appear domed to you?
  • zulururu
    replied
  • zulururu
    replied
    I am working tonight, so I don't have the board in front of me but according to the picture it's BN44-00195A.
    Thank you very much for your time !!!
  • alexanna
    replied
    Whats the number of th power supply BNxxxxxxx?
  • Kjell
    Samsung Series 9 - BIOS issue
    by Kjell
    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
    08-01-2025, 09:15 AM
    09-07-2024, 05:50 AM
  • Nairolf
    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
    by Nairolf
    I have a Samsung DM32D display.
    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
    Here’s what I have tried so far:
    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
    From these tests, I suspect the problem might be on the mainboard. Could anyone...
    08-24-2025, 03:47 AM
  • vincentedel
    Samsung SyncMaster 740n Phase Control Issue
    by vincentedel
    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
    04-22-2025, 12:33 AM
  • Manucsl
    QE65Q800TATXXC Samsung TV Issue
    by Manucsl
    Hello.
    My TV is a QE65Q800TATXXC Samsung TV.
    Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
    Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
    Any ideas to check would be very appreciated 😊
    After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
    02-19-2025, 07:47 AM
