17" LCD Monitor - PGE 1704B/LM1704
+ More Options
Posts
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    Got this monitor recently, it was non-working initially, on power-up, would get a flash from the graphics board info about no RGB signal, and the green power light on the front, flashed on and off continuously. No backlight was coming on.
    Opened it up, and found 3 of the 6 Capxon's in the top right area of the powerboard bulging, so got all 6 of those replaced today, and the panel is now coming on with video signal and backlight.
    There are vertical lines the whole way across the screen though, difficult to photograph, but I've attached an image anyway. Halfway across the room, you wouldn't notice them, but at working distance, they're quite evident. The lines seem to have a reddish tinge to them.
    Anyway, some of the voltages off the power board aren't quite perfect, and I'm wondering if these overvoltages could be causing this issue? Here is a list of the expected voltage, (measured voltage whilst panel is on), and {measured voltage when the panel is off} (may be significant?).
    24V (24.68V) {27.03}
    12V (15.74V) {17.97}
    5V (5.05V) {5.05}
    -8V (-9.11V) {-9.49}
    Any pointers as to what I need to check next?
    Re: 17" LCD Monitor - PGE 1704B/LM1704
    12V reading at 17.97V - almost 18V - looks very dodgy. What caps are there on the PSU?
    • tmcw
      • Oct 2010
      • 382
      • Ireland
      Of the 6 caps I replaced, 5 are Panasonic FMs, the other is an FC.
      The 17.97V was when the monitor was connected to the power supply but off, it drops to 15.74V when the panel is switched on. Possibly still too high.
      The small 7th cap on the board that I didn't replace, I understand is a startup cap, and the monitor probably wouldn't switch on if it was bad, so probably unrelated to the vertical lines issue I'm seeing?
      If the diodes up around the caps were marginal, would they affect the voltages as much as I'm seeing?
      • jetadm123
        • 2169
        Possible logic board problem. Try reseating the two ribbon cables connecting the logic board to LCD panel. Another possible problem is that the caps on the logic board have dried out. Also, check the voltage regulator(s) on the logic board to verify proper output.
          I don't think marginal diodes would cause the issue at hand.
          15.74V is still too high when on. Most power supplies measure under voltage with load for example 11.5V wouldn't be unheard of and is usually completely fine.
          What voltage caps did you install?
          If you installed 16V ones, they are probably toasty, and going to fail.
          Even if you installed 25V or 35V ones, who knows what ripple the PSU has due to other faults? Maybe your multimeter is averaging it and the rail has spikes in the 25-30V range. I've seen it happen before!
          • tmcw
            • Oct 2010
            • 382
            • Ireland
            Ok, reseated the ribbon cables, no difference.
            I've attached a photo of the logic board. The voltage regulators are usually given the "U..." designation, correct? I can see 3 components marked "U", circled in the photo.
            The first 2 (from the left) although slightly different numbers, one has 1117-33, and the other has LD1117.
            The first one: Input: 5.05v; Output: 3.3v
            The second one: Input: 3.28v; Output: 1.8v
            The 3rd one has the numbers "431" on it. I'm not sure what the relevant document is, but the voltages I'm seeing are 2.47v and 13.7v on the left and right (if this document is correct, then the voltages above are on pins 1 and 2 respectively on the SOT-23-3 package).
            • tmcw
              • Oct 2010
              • 382
              • Ireland
              I used the same voltage as were on originally. From left to right in the picture, 2x50V, 1x25V and 3x16V.
              Not sure what my multimeter does, it's an old HP E2377A.
              I have an oscilliscope, can I use it to check for spikes?
              • jetadm123
                • 2169
                The first two regulators have good output. The third one does not look like a regulator.
                • tmcw
                  • Oct 2010
                  • 382
                  • Ireland
                  Thanks for confirming, I was thinking that was the case for the first 2.
                  Ive attached another closeup of the third circled component, definitely marked U8.
                  One thing I noticed is that when the PC went into power saving mode, it switched off the monitor, and the 13.7V on this U8 dropped to zero.
                  • tmcw
                    • Oct 2010
                    • 382
                    • Ireland
                    Also, I took out the oscilliscope, and probed the voltage outputs from the power board, and the resulting voltages didn't seem any noisier than when there is no voltage being probed.
                      Did you use AC coupling? Set V/div down to a low scale, 50mV/div or so. Ripple should not exceed one division either way.
                      • tmcw
                        • Oct 2010
                        • 382
                        • Ireland
                        Unfortunately, I haven't spent much time yet getting to know the scope. I did put the divisions down to about 200mV before I began to see spikes, but I'm really not that clued into how to use it yet with circuits, so what I was doing may be meaningless. I've only played with it with a signal generator as of yet. Need to find some good tutorials, and some time!
                        On a side note, I left the monitor switched on for about 45 minutes (no power saving), and the caps weren't hot at all. The cap nearest the transformer did get a little warm, but it wasn't so hot that it became uncomfortable to hold.
                        • tmcw
                          • Oct 2010
                          • 382
                          • Ireland
                          Ok, I changed a few of the caps on the logic board, but the vertical lines are still present. I changed the one in the top left corner, and the two over in the top right, as all 3 appear to be on the 12V line (which is actually 13.07V as it goes across the ribbon to the panel board (what is the correct name for this board, is it the Tcon board?).
                          The brightness range seems to be much better though.
                          The other caps seem to be involved in the 5V line, which seems to be ok, and the sound in/out area which is ok too, so I haven't changed any of those.
                          I can't seem to trace the 24V line, it goes towards the top of the board from the connector, but seems to disappear under one of the ribbon connectors. I can see a 20.50V on one of the ribbon lines, so presume it comes from the 24V line somewhere.
                          The number on this board is MB-R2523B-DTD, which seems to be used in other monitors, but I can't find a schematic.
                          I've attached 3 photos of the monitor to show the lines. When looking at an angle from the bottom, the lines are very evident; straight on, the lines are sometimes there, sometimes not, depends on the background; and looking at an angle from the top, the lines almost disappear completely.
                          Also, if I go into the menu, and change the screen position, either horizontally or vertically, the lines don't move with the picture, they remain in the same position.
                          Moving the ribbon cables or pressing at the area where the panel board is connected to the panel doesn't alter the picture in the slightest.
                          These symptoms may give someone an idea what might be wrong.
                          I also had a look at the voltages going across the ribbon cable, and was mainly seeing voltages around the 1.2-1.8 range. Also saw a couple of 3.3Vs, a -5V and the 20.5V, but I guess without schematics, not much point measuring these.
                          • tmcw
                            • Oct 2010
                            • 382
                            • Ireland
                            Another thing which may be significant is that when the monitor OSD is invoked, the lines do not go through the OSD.
                            There are lines above and below the OSD, but the OSD is crystal clear.
                            • joshnz
                              • Feb 2011
                              • 969
                              • New Zealand
                              How are you getting signal to the monitor DVI or VGA?
                              My pc
                              CPU : AMD PHENOM II x4 @ 3.5Ghz
                              MB : ASUS M4A89TD PRO USB3
                              RAM : Kingston ValueRAM 16gb DDR3
                              PSU : Cooler Master 850W Silent Pro
                              GPU : ATI Radeon HD 6850
                                This tells us the problem is either with the TCON or VGA/DVI input.
                                Does the monitor have a second input you can try?
                                • tmcw
                                  • Oct 2010
                                  • 382
                                  • Ireland
                                  VGA
                                  There looks like there is space for DVI in another revision, but there is no DVI connector, and lots of unpopulated spaces for associated surface-mount caps and resistors.
                                  EDIT - no second input, just VGA. Also, have ruled out the cable, and have tried another computer, but the issue remains.
                                  • tmcw
                                    • Oct 2010
                                    • 382
                                    • Ireland
                                    If the TCON was bad, would/could I still see a crystal clear OSD?
                                    • joshnz
                                      • Feb 2011
                                      • 969
                                      • New Zealand
                                      Hmmm I was thinking interference in the input signal from vga so maybe.
                                      When i was running a monitor near a pc with the side off my display would go weird/distorted and lots of other things now i use DVI no problems with interference sad you don't have DVI so hard to isolate that as a possible cause.
                                      My pc
                                        Ah - didn't catch that. In which case problem with VGA/DVI input, again try a second input if possible, for example if using DVI try the VGA input, or otherwise.
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • reessi
                                          ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                          by reessi
                                          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                          They are black on the right and gradually fade to nothing on the far left.
                                          They start either after 5 mins or up to 2 hours after so annoying for testing.
                                          They flicker continuously very fast! With a slight pause milli-second every second.
                                          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                          I tested each half by removing the first the left flex from...
                                          06-03-2025, 09:58 AM
                                        • Kikerumbo
                                          Mi Curved Gaming Monitor 34" - Horizontal lines
                                          by Kikerumbo
                                          Thanks in advance for any help you can provide.
                                          I have a Mi Curved Gaming Monitor 34". A few weeks ago it started to show (or not showing) horizontal lines. Of course, it's outside of the warranty period.
                                          After some hours of reading and watching videos I disassembled the monitor and checked the ribbons that go from the TCON board to the panel PCB. If I disconnect the ribbon for the right side of the panel, the other half shows a perfect image. I ordered a "new" TCON, installed it and the issue persists so that tells me it must...
                                          03-14-2024, 02:48 PM
                                        • wattage
                                          by wattage
                                          Hello Badcaps Community,
                                          07-13-2025, 04:41 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
