Sceptre X20WG bad inveter board?
  • Doitmyself
    • Jul 2011
    • 4
    I own a 2005 Sceptre X20WG. It started having problems recently, I would be computing when the monitor would flicker. Not fully on/off but it would become more dim temporarily. As this was happen I could hear the monitor make a buzzing noise that perfectly matched the flickering I was seeing. I could look through the back of the monitor as see/hear in the general area where I suspected the noise was coming from. Since then I unplugged the monitor and used a different one.
    Well recently I disassembled the monitor and looked around in the area where I suspected the bad component was, this time I plug in the monitor (with the case open) and now it behaves differently. It will turn on and look fine for 5 seconds then go black, but the indicator light will still be on. I put my ear next to the 2 components that I suspected to be bad, I can still hear one of them make a small hum noise when the monitor is displaying then the humming stops when the screen goes black. The bad news is that the hum is so soft I can distinguish which component is the bad one.
    The 2 components I suspect to be bad I took a close up picture of. I don't know for sure but I suspect one is an inductor and the other is a transformer.
    The transformer (cube with yellow tape) has this written on it.
    LF-002594-1
    LI TAI 0545
    I also looked over all of the capacitors on the suspected power board. None of them are bulging or leaking or burnt looking
    Thanks for the help everyone
  • jetadm123
    • 2169
    Re: Sceptre X20WG bad inveter board?
    The flickering you describe sound more like bad/failing caps. Considering the monitor is approx 6 years old with the original caps, it might be due for a recap. I count 12 small caps that should be replaced. The two large 450V can be left alone. Replace with Panasonic FR, FM or FC series caps. You can order through digikey.com.
    • POM_MJ
      • Aug 2009
      • 228
      I though, this problem caused by some bad CCFL due to leaked or broken.
      if you have a known good CCFL, you can use it to substitute to find the bad CCFL on the panel.
      | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
      | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
      | 2xWD7500AYYS | 2xHD322GJ Raid0 |
      • PlainBill
        • Feb 2009
        • 7034
        You and jetadm123 are both correct. Either can be the cause. A shorted or open inverter transformer can also be the cause. And there are other possible causes.
        PlainBill
        • Doitmyself
          • Jul 2011
          • 4
          Thanks for the fast replies.
          Jetadm123:
          I am definitely open and willing to doing a recap of this board
          POM_MJ:
          I have never opened up the screen's steel casing to get a look at the CCFLs is this even possible or is it a lost cause if my CCFLs are bad?
          PlainBill:
          If it is possibly a shorted or open inverter transformer can I test it with a DMM or is it just something to try replacing? Is it possible to identify what the transformer specs are in order to buy a replacement?
          • alexanna
            • Mar 2010
            • 1346
            If it gets to the point where CCFLs are suspect and need to be ruled out.
            There is no need to dissemble the LCD panel.
            All you need to do is plug in other CCFLs into the monitor's inverter you're testing.
            This could be done one CCFL at a time but it can take a long time.
            I am fortunate that I have a lot of screens that have problems with the LCD itself, So it's as simple as plugging in another set of CCFLs and see if any thing changes.
            I routinely use the bulbs from a 17” square monitor for testing and have had successful testing on screens up to 22” wide.
            • PlainBill
              • Feb 2009
              • 7034
              Jetadm123:
              POM_MJ:
              PlainBill:
              A quick and fairly reliable test is to measure the resistance of each secondary. They should match within 3%.
              PlainBill
