lp2407 aka fpd2485W No Power
Re: lp2407 aka fpd2485W No Power
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Replaced that voltage regulator and now the monitor is powering up and displaying video. Just waiting for the replacement caps for the video board. There is still a low pitched buzzing sound on the power board, is this something i should be concerned about?Comment
After recapping my power supply, I thought my feeble attempt at repairing my monitor was lost. The power supply wasn't the problem. But by successfully recapping the power supply and not losing a limb in the process, I found the confidence to push ahead. This thread saved me as Plainbill's diagnostic steps to test the 5 regulators on the signal board lead me to find that I had two bad regulators. I'll report back after installing the 3.3v regulators. Thanks to knoxrebel and PlainBill for helping diagnose.Last edited by justincase102; 11-07-2011, 12:06 PM.Comment
I have the same issue- no signs of life at all from the monitor. I noticed a few bulging caps on the power supply, inverter and signal board and replaced them all. I also replaced ALL the caps on the power supply just to be sure. I did make a small error in ordering caps so for the 2x 450uf 35v 125C i got the same but rated for operating temp 105C, installed them anyway.
When I plug in the power supply, I've measured 164v across the big 450v cap and I checked the fuse and its ok obviously.
However, when I check the voltage coming off the power supply (blue area in http://i.imgur.com/X9yaF.jpg)
I'm getting nothing, 0v, from all leads.
I'm not sure what my next step should be, any advice would be greatly appreciated. I'm close to sending it in somewhere or try and order new power supply if possible.Last edited by drdenner; 11-09-2011, 06:03 PM.Comment
1. A cap was put in backwards - don't laugh, it happens.
2. You formed a solder bridge between the leads of a capacitor.
3. The SMPS controller has died.
I'd suggest you investigate the first two yourself. If you don't find anything, take good, sharp, well lit pictures, one of the top and one of the bottom of the power supply and attach them to your next post using 'Manage Attachments'. From that we can suggest the next troubleshooting steps.
3) SMPS = switch mode power supply.
PlainBill is interested in the SMPS controller (IC). It looks like it is mounted on the small pcb board that is mounted vertically next to the biggest cap.
On that board should be a 8 pin IC. A picture of that board will help.
4) Did you change the little cap next to the big 150uF, 450V cap as well? I know you wrote "ALL", but some people may missed that one.
What is the DC voltage across that little cap?
5) I see one Panasonic replacement and I think the others are Nichicon? Is that correct?--- begin sig file ---
--- end sig file ---Comment
Datasheet is at
http://pdf1.alldatasheet.com/datashe.../SG6902SZ.html
It looks like 16V DC is the typical startup threshold (min = 15, max = 17V DC). So it looks like the voltage across the small cap is okay.
You can try to carefully measure the voltage on Vdd. Try not to short out the pins as the chip as a lot of pins.Last edited by retiredcaps; 11-09-2011, 08:57 PM.--- begin sig file ---
Ok so I measured the voltage on the IC and its 15.87v also.
But something weird happened the first time I tried- I think I may have shorted it accidentally, but then the power supply started humming and I measured voltage coming off of it, 5v and 23v. I turned it off and then on, but again no voltage.Comment
Ya but those were intentional since in those spots the trace came off the board so I just tested to make sure the trace was joined to a neighbouring pin and bridged the pins for a better connection. They were already joined electrically. I know the basics of electronics.Comment
Good Morning,
This is my first time posting on this forum, so I apologize if I'm not following protocol. I am kind of a novice when it comes to component level repair, but I used to do a lot of power jack repairs on laptops a few years back, so I am very comfortable with a soldering iron.
I am having the same issue that knoxrebel was. My unit was turning on until recently and now it does nothing when I plug it in except make some noise. I would describe the sound as being similar to turning on an old CRT monitor, but quieter. I's coming from the power board near the big capacitor. It may be normal and may have happened ever since I bought it and just never noticed it, but I thought I would at least mention it.
I do not notice any bulging from the capacitors, and I don't see anything that looks unusual.
I ran through the diagnostics that PlainBill had knoxrebel go through and these are the results that I got back:
voltage across big cap(yellow circles) (C854) - 160v
voltages to inverter board (blue circle):
0
0
0
5.1
0
0
26.3
26.3
voltages across regulators (3 - 4)
chip 1: 5.1 - 3.3
chip 2: 1.25 - .42
chip 3: 5.1 - 1.3
chip 4: 5.1 - 4.1
chip 5: 3.3 - 1.8
Based on PlainBill's response to knoxrebel's voltages, I know that the voltage regulator labeled at chip 3 is bad, but chip 4's voltage is also a little off and the voltages to the inverter board is slightly off too.
Is chip 4 within tolerance or does it need to be replaced too?
Are the voltages coming from the power board within tolerance, or do I have a problem there too?
Thanks for the help!
- TComment
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
