Envision 985e 19" CRT Flat Screen
  • brethin
    • Dec 2008
    • 1907
    I have a Envision 985e 19" CRT flat screen monitor that just stopped working. It has power (the power light comes on) but no display not even the menu. Wondering if this is even worth trying to fix or should I toss it I have no experience with CRT's.
    master hoarder
    • May 2008
    • 12175
    Re: Envision 985e 19" CRT Flat Screen
    Well my opinion my be biased since I'm a CRT-head (wait, is there such a thing?... okay I guess there is now ), but I think you should fix it.
    What noises does it make? Does it try to start up? Do you hear degauss coil when you cycle power from the power button?
    I'd say open it up and look for burned components. Maybe post pictures too. A schematic may also help.
    I'll wait for other people to chime in since I don't have that much experience with CRT repairs either (only fixed 2, but both were simple PSU issues).
    Don't worry about the high voltages - the HV rails don't have enough current to kill when the monitor is off. With a bit of caution, you should be pretty safe.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
