NEC MultiSync 2470WNX
  • Colt45ws
    • Jan 2009
    • 174
    Just noticed today some very light vertical lines running through on the left ~1/6 of the screen. I pulled it apart, but nothing obvious looks wrong. Any ideas?
    btw, it is filled with Chemi-Con and Rubycon.
  • jetadm123
    • 2169
    Re: NEC MultiSync 2470WNX
    You can try reseating the flat ribbon cable from the logic board to the LCD control panel board. Unfortunately, my fear is that the flat ribbon flex cable that connects the panel control board to the LCD panel itself is starting to separate. You can try pressing down on the cable contacts to see if the lines go away (or the number of lines may increase). No fix for this, since the connections are made using specialized equiptment at the panel manufacturing plant.
    • Colt45ws
      • Jan 2009
      • 174
      Really? Well, that sucks. Guess Ill run it until it dies (or gets extremely annoying) and save money for a replacement in the mean time.
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • jeyoung12
        Samsung QN50Q60t lines on screen
        by jeyoung12
        Hi all
        I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
        My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
        This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
        It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
        So....i don't know what end of the C ribbon to work with...
        02-26-2024, 10:38 AM
      • Rubenlily
        Samsung QE50Q67TAU - horizontal lines
        by Rubenlily
        First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
        I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
        I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
        I'm no expert but I've done the tape...
        08-16-2023, 01:12 PM
      • visionbluedemon
        Help. Sony kd-65x85dj vertical lines
        by visionbluedemon
        First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
        Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
        tried blocking LC lines too, but same results
        is it lcd panel issue or tcon board issue?...
        07-25-2025, 04:56 AM
