Dell 2007wfp - 2 sec to black
+ More Options
Posts
  • mojonba
    • Jul 2011
    • 9
    Re: Dell 2007wfp - 2 sec to black
    So I opened the LCD and lo and behold the wiring is damaged on the top right corner (same corner with the arcing sound). See attached pic. Any good place to get replacement ccfl other than http://www.ccflwarehouse.com/. Thanks Guys.
    • Toasty
      • Jul 2007
      • 4171
      Can't fix the wiring? A little bit of wire and some silicone sealant should be good. Just -wait- 12 hours for the stuff to fully cure.
      CCFL Warehouse is probably one of the best around with a huge selection. Goods are professionally packed and shipped.
      veritas odium parit
      • mojonba
        • Jul 2011
        • 9
        Toasty: I fixed the wiring myself and used some liquid electrical tape instead of silicone which cures in 15 minutes. I am typing on it right now. Working perfectly. Thanks much guys.
        • alexanna
          • Mar 2010
          • 1346
          Here some more pictures of the CCFL wiring on 2007WFp.
          This monitor was having the 2 second to black, But also having some real violent flickering of the CCFLs.
          There were 5 CCFLs with problems.
          Luckily I had the correct adapters, to be able to substitute CCFLs.
          You can see some darkening on the ends of the CCFLs,But this one will be able to be repaired with some rewiring.
          Its full of elite caps that I will also replace.
          • HTR-Informatique
            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
            by HTR-Informatique
            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
            I also changed the screen because the PC fell and the screen was broken.
            I changed the battery with a new and original battery.
            I also had corrosion/oxidation on the...
            02-09-2025, 06:51 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • jake-b
            dell e6540 boots to black screen (no dell logo)
            by jake-b
            good morning all,
            i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
            01-08-2024, 10:29 AM
          • DanPoka
            by DanPoka
            02-15-2025, 05:05 AM
          • valscu
            EIZO SW3031W monitor blue color instead of black
            by valscu
            I have an Eizo SX3031W monitor and after a period i had problems with the tcon board. I did reflow, it went well for a while after but the problems appeared again. The second reflow attempt was a failure, the tcon board stopped working. In the meantime, I bought a perfectly functional Samsung 305T monitor from which I took the tcon board and installed it in the Eizo monitor. Since I turned on the monitor, the blue color appeared in the background instead of black. And also in Windows, appears blue instead of black. I tried various settings from the monitor and driver settings but...
            08-10-2022, 02:08 PM
