Dell 3007wfp - Screen snapping and snow
  • tubeman
    • Jun 2011
    • 3
    I have a Dell 3007wfp
    My monitor works and the image quality is very good. However, the screen will "snap" several times an hour and about once/twice a day the display will snap and be covered with "snow" (see attached file). To get rid of the snow i have to power off and on the monitor and most times this works the first time. The monitor and computer are both plugged into a UPS power supply. The monitor is powered on 24hours a day and has been for several years. Would anyone happen to know what causes this? I have had this issue with the monitor connected to two different computers (one Windows server 2008 and Mac OSX).
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell 3007wfp - Screen snapping and snow
    A little more information would be helpful. "Snap" suggests an audible sound. Is that what you are saying, or are you saying there is a sudden change in the display with no accompanying sound?
    PlainBill
    • tubeman
      • Jun 2011
      • 3
      The "snap" is a split second change on the screen. The screen does not go black but more like the "snow" covers the screen for a split and then back to normal. It is hard to say what is really on the screen because it happens so fast. there is no sound to this but it sure does feel like it there should be, like a pop. there is no one program that causes this to happen more than another. and my overall image quality had not decreased in anyway from what i can tell.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        This sounds a lot like a bad solder joint that intermittently causes an open somewhere.
        Mann-Made Global Warming.
        - Dr Seuss
        • jetadm123
          • 2169
          I suggest you open it up and post some photos of the power and video/logic boards per PlainBill's links in post #2.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • kilog
            Snow on screen and no start Do I have to replace my CF53-MK2
            by kilog
            Hello friends,
            Last week when I tryed to start my CF53-MK2 it just stop starting
            and when it starts it displays snow and dansing and coloured lines on the sreeen as you can see in the attached video.
            Some time it may show the startup Bios screen for a 3 to 10 seconds and then immediatly starts to disply snow and coloured lines.
            I tested the RAM it is correct.
            I tried to hook the machine on a HDMI screen, nothing.
            I am not sure that the computer goes far to be able to show anything on an additional monitor.
            Please I need your...
            09-27-2023, 08:00 AM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • burbutsalos
            LG 55sk8000 plb ..snow in the middle of screen but can see that picture exists there
            by burbutsalos
            Hello everyone.
            I have this TV set which has this issue. It shows a vertical bar im the middle of the screen.
            The panel has 12 cofs and the problem seems to be on the territory of the first cof on the right side.
            The tv fires up and you can see a good picture exept that vertical part where multicoloured pixels exist.
            The strange thing there is that you can see behind that snow that it shows picture but as if there are these pixels in front so you cannot see clearly.
            The effect is there even on a completely black screen.
            The screen...
            10-21-2023, 02:57 AM
