Viewsonic VA1616W Non Starter, No Lights, Suggestions Please!
  • imalearner
    • Apr 2010
    • 38
    #41
    Re: Viewsonic VA1616W Non Starter, No Lights, Suggestions Please!
    NOW, this is getting personal. A photograph of the label on the back of the monitor would be useful. There seem to be several different models of VA1616W.
    PlainBill
    This bit I can do easily PlainBill. I searched a bit myself for this and found that most results, with my model number, show up in Google - in every other language under the sun, except the one I can understand.
    Hope this helps, photos as requested.
    Imalearner
    • imalearner
      • Apr 2010
      • 38
      #42
      Originally posted by Rtech
      Youa re correct.Although the 'Banded' end is negative,,the diode is rectifying the Voltage coming in through the +ve end, so you are right.Lets also add something else.You will notice that after the Voltage goes through the fuse IF and WHEN it is refitted,it goes onto the pins and then up under a resistor RJ32,turns right,and goes to other components.You will notice one of these, which I have marked on the attached...it is marked Z31 but just looks like a Black blob, no matter how I magnify it,,is there a component there, or does it look as though one has burnt out ???????//
      Sheeeessshhhhh! Do I need a magnifier or what? Had a looksie at component Z31 in close up, and depending on which angle the light hits it, it is possible that it has cracked solder on one side?
      See what you think.
      Blast and damn it I have to go out, Family calling - back onto this asap - prob, tomorrow.
      Cheers for now.
      Imalearner
      • Rtech
        • Jul 2010
        • 1095
        #43
        Cannot tell..Please tomorrow measure the voltage on the Diode as requested,THIS is more important than anything else!!,and if it is 5V, then ensure it is on both side of L53.If it is then replace the fuse.and see if it drops off....if so then we are looking to test U31, and also need to decide what if anything you need to do about Z31.
        • imalearner
          • Apr 2010
          • 38
          #44
          G'morning all!
          Picture reposted as I noticed I had labelled the other one incorrectly.
          Measured 3.5V at start, climbing to 8.9V over 90 Seconds?
          Befuddled I sit still, in awe, of everything I know- I don't know
          Imalearner
          • Rtech
            • Jul 2010
            • 1095
            #45
            Why did you label it incorrectly ??the voltage you have advised is DC ?? Yes?? as requested.Presume you checked it through L53 as requested, and have put the fuse back as requested,and the voltage returns to approx 2.5 volts DC ??
            If you have ,then part code of U31,the three pin transistor,will help.Also if all the above happens,then with the unit switched off,and with U31 still connected, label the pins 1,2 and 3,in any order you wish,and with the meter switched to resistance measurement put Black on 1 and measure 1-2,1-3 and 2-3,,,then reverse the leads and do the same again.Any reading 30 ohms or less will indicate a problem.
            • imalearner
              • Apr 2010
              • 38
              #46
              Why did you label it incorrectly .
              I must have been rushing!!! Sorry.
              What I meant is, I had 'titled' the photograph wrongly.....that's all.
              I called part No J35, J32 by mistake.
              Any help I can get I am very grateful for - likewise, any help I can give, even if it's just a few photographs -correctly titled - that may help others - must be right.
              So, nothing else has changed or submitted in error.
              I just checked the reading again between J35 and D32 and it's the same as before.
              Cheers
              Imalearner.
              p.s. Because you said (in post 44) if the voltage is 5Volts.........and the voltage I have measured is not 5v (but sliding from 3.5V to 8.9 over 90 seconds) I have not done anything else. This might just be me being too dim witted to figure it out myself but I would prefer to hold my claim to ignorance. Hope I am making sense.
              What do you kindly suggest next?
              Ta!
              Imalearner
              • Rtech
                • Jul 2010
                • 1095
                #47
                Just complete as I asked, the voltage will be higher, there is NO current being drawn is the reason, just do as I asked, as I am spending a lot of time with this, AND missing my Test Match Cricket !!
                • imalearner
                  • Apr 2010
                  • 38
                  #48
                  OWZAAAAAAAAAAT! Sorry matey flip. It's not meant to be stressful for either of us.
                  I will do exactly as you say - when I know exactly what that is.
                  I am very obedient when under instruction, but so that I do not mess up - I must ask to inform myself - how not to. It might come as second nature to you all this technical stuff, but Imalearner is what I am
                  Cricket I am told is a gentleman's game -is it?
                  In front of me is a board with two replaced caps, as instructed, one fuse is removed.
                  Please, just tell me which test to complete, okay I'm thick - please get over it - I have to every day!
                  What's the score by the way
                  Cheers
                  Imalearner
                  • Rtech
                    • Jul 2010
                    • 1095
                    #49
                    Post 45, explains as simple as I can, because I know you are a learner, what I want you to do,don't worry if you do not understand why, if necessary will explain.Just do those please. ...Cannot tell you the score.......I just MISSED it....lol
                    • imalearner
                      • Apr 2010
                      • 38
                      #50
                      HAHAHAHAHAHAHAHAHAHAHAH! Whoops sorry again
                      While I hope you enjoyed your cricket...
                      I have checked voltage on both sides of LS3 (but can't find an L53 anywhere...I think that's the one you mean?) Er..well I hope so!
                      To be sure, it looks like a copper coloured coiled spring, sitting vertically between the edge of the board and C33. Anyway, hoping this is the part you mean and the Voltage is 8.9Volts.
                      I Replaced fuse and YES voltage returns to approx 2.5Volts DC
                      Part code for U31 is in the photograph - best if I leave you to decipher.
                      Test on U31, followed as described, with meter set on lowest setting (200ohms) all contacts displayed 1 on my digital meter. I checked, double checked and checked again many times.
                      So, next........I suppose I should I be replacing the U31?
                      Ta!
                      Imalearner
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #51
                        If your multimeter reads "1" or "OL", it means the measurement is outside your chosen range. Don't confuse "1" on the left hand side of this display with 1.0 on the right hand side. The first means out of range and the second means 1.0 unit of your measurement.
                        So which are you reporting?
                        --- begin sig file ---
                        --- end sig file ---
                        • Rtech
                          • Jul 2010
                          • 1095
                          #52
                          Most Monitors have a 5V 'regulated' supply for the Logic Board,and a higher Voltage for the Inverter,and the latter you have already measured at approx 18v,which if the unit was working would be much closer to 12v,and thereby showing that that side of the circuit looks fine.
                          The GTL741 is a Voltage regulator,and with a reference voltage of approx 2.45 volts applied to it,you can vary the output voltage,by using external resistors.In this case it seems that all you are getting out is the ref voltage and not the required 5V to operate the Logic Board ,so the fault is certainly in that area....HOWEVER with no schematic,and its not possible to trace what goes where even when magnifying that area of the board,you would have to start testing all the Small Surface mount components to try and determine which are causing the problem,and that is not easy even for someone with lots of technical experience.The fault may be the GTL741 itself, and that would be the first component I would test..by replacement....but it may well be its peripheral components.
                          It would seem that the owner would neeed to try and purchase a replacement board from Ebay maybe.The only other way, would be to find a working board and by doing comparison test for each component in the area,you might be able to find the problem.
                          A lot of effort to get to this stage with no 'happy ending' but sometimes these things happen,but hopefully you have learned something from the experience.
                          • imalearner
                            • Apr 2010
                            • 38
                            #53
                            Having put fresh batteries in before the readings were taken I am confirming a reading of 1 on the left hand side of the display, for all 6readings made, whilst the setting of my meter was on 200.
                            Also, to double check the meter is working properly I touched the red and black leads together which gave me a reading of 00.4 I think that's accurate enough?
                            I am naturally curious so I changed the meter up to the 2k setting.
                            I redid the same six tests. This may seem pointless to some, but I did it anyway and I get three stable readings, one reading that reaches 1.99 and then goes out of range, and two other readings out of range.
                            I don't know if this is relevant, but I am reading and digesting as fast as I can.
                            Thanks for the explanations, it can only help me in due course,
                            Gratefully,
                            Imalearner
                            P.S. I will gleefully report back if, and, or when, I get this sucker sorted.......but please don't hold your breath. :o)
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #54
                              When testing for a shorted component, we are only interested if it measures in the low ohm range (say 30 ohms or less).
                              If the component measures "1" on the left hand side with the multimeter set on the 200ohm scale, then it implies the component is not shorted. That is, "1" means the reading is greater than 200 ohms.
                              At this point, we don't care if it is 201 ohms or 2.1M ohms, we just know it is not shorted. This is what Rtech wanted to know in post #45.
                              This tutorial may shed more light
                              http://www.sparkfun.com/tutorials/202
                              • imalearner
                                • Apr 2010
                                • 38
                                #55
                                Ahaaaaaaaaaaaaaaaaa That's brilliant. It seems I must have been thinking in reverse. So, the readings I have got on that part, suggest that it is okay after all? Thankyou very much.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  As you have noted, a likely suspect is the circuitry around U31. This is most likely a TL431 or equivalent. Usually a voltage divider is used to program the voltage. In this case, the most likely culprit is the pull down resistor of the voltage divider.
                                  The pins of the reference are numbered in the attached picture. Pin 1 is the reference input of a TL431, the resistors toward the top of the yellow rectangle are the most likely suspects. A closer picture would be helpful.
                                  PlainBill
                                  • imalearner
                                    • Apr 2010
                                    • 38
                                    #57
                                    ....... A closer picture would be helpful.
                                    PlainBill
                                    Sorry PlainBill - I have just logged on to tell you guys great news....it's fixed!:Cheers everyone! As I write it's on my 'test' bench, and my fingers are crossed.
                                    After the heady exercise of digesting some of the info in this thread I resigned myself to the fact that the job was becoming beyond my few skills just yet. So I put a call in to an old friend who lives a few miles from me. Told him everything we have tried here. His speciality is Sony playstation and wii, with a few hundred TV's and videos for good measure. Thankyou Raf Sabir in Cardiff.
                                    Anyways, he went through everything checking my handiwork - thankfully it passed, and was as perplexed as us lot here - especially me.
                                    Then he scoped the board.....voila! Ceramic Capacitor Ca1 was cracked. So, off it came and he replaced it with summat off a playstation.
                                    So I thought I must tell you guys, it all helps our education. Thankyou for your help, I'm sure to be back, but I'll read a bit more and practice my soldering too.
                                    Photographs to help anyone else with similar experience.
                                    Cheers all.
                                    Imalearner
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Shoot, don't that beat all. Glad to hear it's working.
                                      PlainBill
                                      • ratnesh3107
                                        • Sep 2011
                                        #59
                                        What is Viewsonic va1616w Ca1 Value on Power Card
                                          HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 02:00 PM
                                          Acer TravelMate P214-52-566U+STARTER KIT 15'' Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P214-52-566U+STARTER KIT 15'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-566U+STARTER KIT 15'' boardview and P214-52-566U+STARTER KIT 15'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 07:20 PM
                                          Acer TravelMate P215-52-56G5+STARTER KIT 15'' Notebook P2 Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate P215-52-56G5+STARTER KIT 15'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P215-52-56G5+STARTER KIT 15'' boardview and P215-52-56G5+STARTER KIT 15'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                        • jake-b
                                          dell e6540 boots to black screen (no dell logo)
                                          by jake-b
                                          good morning all,
                                          i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                                          01-08-2024, 10:29 AM
