Re: Dell 2407WFPb Monitor - Bad Cap
plzz tell the number of this little thing i cant see in this foto becaus this is so little plzz tell me that the number
Re: Dell 2407WFPb Monitor - plzz somebady tell the number of this thing i cant read
Hello to all community,
I also have a 2405 with a failed C605 and all the company of MOSFET and IC that it brought down. In this thread it was mentioned only ZD601 (15V). Even if the remaining Zeners should not be affected by the cap failure, I measured ZD602 and ZD603. Both are 24V, if anybody wanted to know.
CheersLeave a comment:
Just a quick update: After have exchanged all components listed in #448 of this thread, the monitor powerd up! I'm writting this update with the newly repaied monitor. Totally amazing.
Ps. did change all caps on the power supply board, but not on the CCFL driver board.Leave a comment:
Yes, only the revision no. is A02: ie. 48.L1E02.A02Leave a comment:
@lipeng, please re-post in 2405 thread or make a new one.
Is this the same board you are working on?
http://s807.photobucket.com/user/bud...?sort=3&page=1Leave a comment:
I have a 7-8 yrs. old Dell 2405fpw monitor and also had problem with the power supply board. So far I changed the following components, but when put it back and tried to switch it on, nothing happens:
C605 / 450TXW100MEFC18X35 CAPACITOR, RADIAL, (450V, 100UF, since I couldn't get a 120 uF at the moment)
Q651 / STP10NK60ZFP MOSFET, N, TO-220FP
IC651 / L6561D PFC 90UA START + DISABLE, SMD, 6561
R670 / PNP1WVJT-52-0R22 RESISTOR, 1W, 5%, 0R22
F601 / 0001.2510 FUSE, ANTISURGE, CERAMIC, 4A
C622 / EEUFC2A1R0 CAPACITOR, RADIAL, 100V, 1UF
The fuse kept intact, but no indicates for any life of any sort, what could I else do?Leave a comment:
Success reviving Benq FP241W
Thanks to the posts in this forum, I was able to fix my Benq FP241W that wasn't powering on and saved a few hundred dollars on a replacement. The Benq FP241W uses the same power supply board as the Dell 2407 and I noticed brown leakage at the positive terminal of the 120uF 450V capacitor (C605) and the ceramic coating on R670 was flaked off. I replaced the components listed by elvena, micdis and others. I didn't test the components to see what had actually failed - I just replaced everything listed below.
Component ID / Replacement Part / Digikey Part Number
C605 / Rubycon 450QXW120MEFC18X31.5 / 1189-1377-ND
Q651 / STMICROELECTRONICS - STP10NK60ZFP / 497-5892-5-ND
IC651 / STMICROELECTRONICS L6561D013TR / 497-4582-1-ND
R669 / Panasonic ERA-8AEB1021V / P1.02KBCCT-ND
ZD601 / Vishay TZMC15-GS08 / TZMC15-GS08CT-ND
IC601 / ON Semiconductor NCP1200D100R2G / NCP1200D100R2GOSCT-ND
R670 / Yageo PNP300JR-73-0R22 / 0.22AECT-ND
F601 / LittleFuse 0234004.MXP / F2692-ND + F1504-ND fuse holder
C622 / Nichicon UPS2A010MDD1TD / 493-5378-1-ND
Q654 / Fairchild Semiconductor MMBT3906 / MMBT3906FSCT-ND
D655 / Diodes Inc. 1N4148W-7-F / 1N4148W-FDICT-ND
As a precaution, I replaced these other caps on the power supply board:
C711-C715 / Panasonic EEU-FM1V471 / P12415-ND
and these three caps on the CCFL driver board:
? / Nichicon UHE1V221MPD6 / 493-1579-ND
I'd never de-soldered/soldered surface mount components before, so I practiced for a while using a dead board. I found I had to be careful when de-soldering ICs and SMT transistors to avoid tearing off the contact pads.Leave a comment:
hi got that thanks! do you know what type of diode is used? as there is no info on them. also that link was for the 2407 if I get service diagram for that are they about the same?
thanksLeave a comment:
You can try this link, post #8
https://www.badcaps.net/forum/showth...WFPb+schematicLeave a comment:
Hi does anyone have a service manual or a schematic for this board I can I have pleaseLeave a comment:
Put your meter in diode mode and check to see if it is still tested out like Diode.
Have uploaded the video to Youtube had no one to hold the camera for me will upload a better one tomorrow but think you may be able to get the idea. all the top right is short
http://youtu.be/ICJcvwSdgIQLast edited by Nickkip; 09-11-2013, 07:40 PM.Leave a comment:
Hi Thanks for your replay I will post a video up to youtube bit later on see if I can show what im getting as where the top of the board by r615 that part of the board is all going to grown.Leave a comment:
Please post good clear pictures of YOUR board. R615 is 0.22 Ohm resistor, so what do you read on your meter. Pictures of C611, ZD601?Leave a comment:
Hi Guys I have a problem with the same power supply 48.L1E02.A03 its reading short on a few places im still new to this. Would be great if anyone could point me in the right direction
R615 is short
C 611 is short
ZD601 is shortLeave a comment:
by Borse2008Hi everyone,
Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:- The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
- There’s
07-15-2025, 04:55 AM -
by LapsmithWhile installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
Channel: General Capacitor Questions & Issues
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by Jesus CoderHello everyone,
I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...-
- Loading...
