Dell 2407WFPb Monitor - Bad Cap
  • dogletico
    replied
    Re: Dell 2407WFPb Monitor - Bad Cap
    Originally posted by selldoor
    This is not going to be easy!
    Can you post good clear pictures of your boards.
    When it "locks" do you mean
    1 picture stays on
    2 screen goes blank power led stays on
    3 screen goes blank power led goes off
    4 screen goes white.
    OK.
    On the PC (VGA), after about 30 minutes, the screen goes black, the LED on and dead controls.
    Connected to a satellite receiver (TV) (VIDEO) after about 30 minutes, the screen is with mixed colors and illuminated LED controls and dead.
    Turning off the power on again and everything back to normal until locked again.
    Post photos later.
    Grateful.
  • selldoor
    replied
    1 picture stays on
  • dogletico
    replied
    Hello friends.
    Won by a monitor 2407WFPb is defective and friend who gave me could not waste time on concert.
    Well, ask experts to help this wonderful Forum.
    Here is what I noticed in the defect:
    Perfect operation, image and fully operational controls, but after 30 minutes, she literally "LOCK". Turns off the power and turns the power on and it starts normally and back to work for another period.
    I opened the monitor and visually saw no fault in the components.
    I suspect there might be some problem with the "Firmware".
    I leave here so this case to analyze.
    Hugs.
    Ps: Sorry for my English, I'm using a translator.
  • selldoor
    replied
    Ok - Good luck
    Its always useful to report back as it may help others in the future.
  • aschi-ch
    replied
    I did not find that russian site so far - thanks!
    On my board, C628 is a fair bit 'higher' (or thicker) than (what remained of) c626.
    Anyway i measured C628 - it's 1uF.
    R669 and C626 form an RC-Lowpass for the current-feedback,
    currently i don't know the switching-frequency, but 1microfarad seems to be to much:
    R669 is 1k, so the filter has a Frequency of 195Hz, which i think is to low, since the switching-frequency is probably somewhere around 10kHz.
    I think i will try with ~1-10nF (159kHz - 15.9kHz).
    In the meantime i found the Application-Note AN966 from ST.
    There i can find one circuit example, where they have a filter in the feedback-path.
    There they have 330Ohms and 1nF Capacitor.
    You will get a feedback when i replaced all the failed parts, but i have to order them first.
    And befor i can order, i have to finish the BOM of another Project, because i want to order all parts together.
    So it could take some time till i have any feedback.
  • selldoor
    replied
    I cant find any reference to it as being faulty but on this russian site
    http://monitor.espec.ws/section33/post1216836.html
    there is a clear picture of it and is is on their wiring diagram.
    If it doesnt work without it C628 looks to be the same size and if you have any facility to measure that, perhaps try one the same value.
    Unless anyone comes up with a definitive reply.
  • aschi-ch
    replied
    Yes, ok.
    No, unfortunately there are no markings.
    It is a standard SMD case, probably 0805 size.
    Voltage would be verry low, this cap goes from Pin 4 of the L6561 to Ground.
    Pin 4 is the current-feedback-voltage, measured by the famous R670, which is 0.22Ohms.
    I would assume that this cap is around ~10nf, it is just to filter the current-feedback.
    On the Typical Application Circutis in the datasheet of the L6561, there is no capacitor in that position,
    maybe it works even without...
  • selldoor
    replied
    Sorry I did try to find a pic but couldnt see one.
    Re there no markings on it - The physical size is also a clue.
    If you have made out a schematic do you already know the voltage?
  • aschi-ch
    replied
    Thank you.
    Yes it is the same board, but unfortunately there are only the Electrolytic caps listed.
    C626 is an SMD ceramic cap.
  • selldoor
    replied
    Looks like this is a list of caps (IF YOUR board is the same) so you can work out
    which it is by elimination
    https://www.badcaps.net/forum/showpo...2&postcount=33
  • aschi-ch
    replied
    I am currently working on a Power-Supply of a 2407WFPb.
    Trough the help of you in this awesome Forum, i was able to find replacement-Parts for all dead components on my board, with exception of one:
    On my board, C626 is dead as well. Does anyone know, what capacity C626 is?
    Would be great to have more information on that.
    btw:
    If anyone needs more inforamtion about this board:
    I have drawan the complete scematic of that board (currently only by hand as a draft) by following the traces and mesaunring the components.
    Now i am adding all known information of all the Parts (Ratings, values, replacement-parts etc.)
  • danfisch
    replied
    Are the PSU boards for the 2405 and 2407 boards interchangeable? There seem to be a lot of 2407 boards floating around on ebay / taobao, whilst the 2405's are a bit thin on the ground. The connectors mark CN701 (to logic board) and CN702 (to inverter) look identical in terms of dimensions and wiring colours.
  • braxton
    replied
    my 2405 seems to be in standby mode and does not switch over to "on".
    Is there a way to bypass the on-off switch or test it at the board?
    replied
    The reason it does not work may due to the sub-power supply board has the problems, there are buck regulator circuits that convert the 19v to lower voltages that you need to check.
    http://s807.photobucket.com/user/bud...?sort=3&page=1
  • Misterkeeks
    replied
    Originally posted by braxton
    Has anyone got this mod to work on the 2405? I tried this mod with a 19V 4A power supply and still no power???
    I too would like to know this. Considering trying it, seems easier than troubleshooting.
  • braxton
    replied
    Also, does this mod replace the need to use the power on/off button on the 2405? The reason I ask is that I'm beginning to suspect that I am having a power on triggering problem with the power switch.
    How can I bypass the power on button switch on the main board itself?
  • braxton
    replied
    Originally posted by AdrianM
    Tyan, the speaker socket/power mod is a simple three-step process:
    1) In the photo attached below I have marked both ends of L702, which is to be removed from the PCB, with magenta crosses. De-solder or just cut both ends of this inductor (a bit of wire that passes through a ferrite bead on the component side). This isolates the power socket from it's normal supply circuit.
    2) The short blue line shows where to solder a bridging wire to permanently ground the switched contact for the socket CN703 - making it seem that the speaker isn't plugged in. A blob of solder across C718 would also do the trick.
    3) Run a decent gauge stranded, insulated wire between the points marked with an orange line. To get a good solder joint on the land between C713 and F701 scrape away the lacquer first. The other end of this wire goes down onto the middle pin of socket CN703 which is already quite well exposed for soldering.
    That's really all there is to it! The central pin in the speaker socket may be a little smaller than the power-brick plug (2.1mm vs 2.5mm I think) If it doesn't connect very well, it might be necessary to roll a small piece of copper or tin shim to increase the diameter of the centre pin. If that's too fiddly then you can always swap the socket for the correct sized one, or find an adaptor lead. I slipped a slender wire crimp insert over the pin which worked a treat.
  • rocket
    replied
    Thanks to this board I have managed to repair my 2405. Many thanks to the contributors. I had the usual initial failures:
    R670 (blown - replaced by cheap metal film 2W off ebay)
    C605 (blown - replacement sourced from ebay again)
    IC651 L6561D (destroyed - replaced over ebay)
    Q651 SK3502 (shorted pins on testing - replaced via ebay)
    Oddly the fuse was still intact but the monitor did not power on.
    Then replaced:
    IC601 NCP1200D (from RS couldn't wait!)
    ZD601 15V 0.5W zener from local shop
    Fired up perfect!
    replied
    What is the IC designator, IC651?
  • arber
    replied
    Originally posted by budm
    Put your meter in diode mode and check to see if it is still tested out like Diode.
    plzz tell the number that blcak little chip i cant see
  • Borse2008
    Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
    by Borse2008
    Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
    I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
    • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
    • There’s
    07-15-2025, 04:55 AM
  • Lapsmith
    Fried capacitor on Dell-5520. Guilty as charged.
    by Lapsmith
    While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
    07-06-2025, 11:08 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
    by momaka
    03-15-2023, 10:17 PM
  • Jesus Coder
    Issues Reviving Old Dell 2408WFPb Monitor
    by Jesus Coder
    I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
    06-25-2023, 02:33 PM
