Dell 2407WFPb Monitor - Bad Cap
  • sgt_az
    • Jul 2009
    • 9
    #421
    Re: Dell 2407WFPb Monitor - Bad Cap
    I've got a Dell 24" monitor that has burnt surface mount components. One is a transistor (Q654). The part has the following markings: "ZA 49". I can't find any information on that part number. Does anyone know where I can find a cross for it? The second burnt component is IC651. I can't read anything on IC651 but I found the part number through another BadCaps thread. https://www.badcaps.net/forum/showthread.php?p=178133 The 120uf 400V capacitor is also bad. Any information on Q654 would be greatly appreciated. Thanks.
    • pkanar
      • May 2013
      • 19
      Q654: 2N3906S by KEC (PNP transistor 40V, 350mW, in SOT-23 package)
      IC651: L6561 by ST Micro (power factor corrector, in SO8 package, can also use L6562)
      C605 is 450V
      • BastiaanNaber
        • May 2013
        • Netherlands
        #423
        Can anyone tell me how IC651 is supposed to be oriented on the board? Attached is the picture of my replacement part and also the way that I'm holding the board. Thanks in advance!
        • sgt_az
          • Jul 2009
          • 9
          #424
          IC651 should be oriented with pin 1 down and to the left by the black dot on the board. Pin 1, where the indention is on the encapsulant, should be toward capacitor C621 just below it in the orientation you took the photo in.
          • BastiaanNaber
            • May 2013
            • Netherlands
            #425
            Thanks everyone for your help. I have been able to restore my wives monitor.
            I have replaced the following:
            R670 0.22ohm Farnell 1903854 (10)
            C605 120uF/450V Farnell 1828683
            IC651 L6561D Farnell 9882464
            IC601 NCP1200D Farnell 1652430
            Q651 STP10NK60ZFP Farnell 9935517
            ZD601 15V 0.5W (diode) Farnell 1469418
            Fuse holder and Fuse Farnell 1162740 and 1354592
            I hope it will keep going for a while. I will also replace the big cap in my own 2407, just in case.
            • jetadm123
              • 2169
              #426
              Glad to finally see some success stories for this monitor. And thanks for sharing your success story with us. Just out of curiosity, was the large 120uf leaking?
              • pkanar
                • May 2013
                • 19
                All failures of the big cap seem to be the same: no evidence of leaking, but corrosion and eventual disconnection where + terminal enters the body.
                • oko
                  • Jul 2013
                  • Ukraine
                  #428
                  Hi guys, help determine which there were? received in this form! thanks for the help! may have a schematic for this power supply??
                  • VIPER1988a
                    • Jul 2013
                    i tried the external power mod that is on page 8 or 9 of this thread. still no go. i get 20v on yellow orange and red wires to inverter board, 20v on red wire to display board, and only 1v on the green wire to display board. i believe the green wire is supposed to be 7v. any ideas where the issue could be? the external supply i used was 90w 20v 3.5a
                      The main power supply is only single output around 19VDC, then other switching power supplies on another board are generated from this 19Vdc for running other circuits.
                      http://s807.photobucket.com/user/bud...?sort=3&page=1
                      • VIPER1988a
                        • Jul 2013
                        forgot to mention. i have the 2405fpw not the 2407
                          Oh, OK. What DC voltage do you get at the main 450VDC filter cap, measure right at the two pins of the cap? Can you also post the pictures of your board and the location of the pins you are measuring the voltage?
                          "i tried the external power mod that is on page 8 or 9 of this thread. still no go. i get 20v on yellow orange and red wires to inverter board, 20v on red wire to display board, and only 1v on the green wire to display board. i believe the green wire is supposed to be 7v. any ideas where the issue could be? the external supply i used was 90w 20v 3.5a" since the pin out of the 2407 are not the same as 2407, we need verification, especially 20v for the DISPLAY (T-CON?) is not right at all, it should be ONLY either 5 or 12V or may be you mean the MAIN Board?.
                          The Green and Blue wire on the whit connector of the power supply that goes to the main board are for BL_ON (Backlights ON), and Backlights Dimming signals which are generated by the main board and routed through the power supply board out at the other connector of the power supply board to the Inverter board.
                          • lexwalker
                            • Feb 2011
                            • 307
                            • Malaysia
                            #433
                            Just trace the pins and figure out the circuit. From the picture, judging from the SMPS transformer nearby, I would guess those missing ones are schottky rectifiers. If the connections to the pins are direct from the transformer then definitely they are rectifiers.
                            • oko
                              • Jul 2013
                              • Ukraine
                              #434
                              I can not afford so check out! to the name of the element choby I could buy and put them in there, help me please:!
                              • pkanar
                                • May 2013
                                • 19
                                I don't have a 2405, or have the 2407 board handy, but looking at the picture (page 5 of this thread), they look like Schottky rectifiers/diodes in TO220FP package (common cathode on middle pin). The 5 capacitors are 470μF, 35V, 105°C (Elite EJ series).
                                • Nickkip
                                  • Sep 2013
                                  • 9
                                  Hi Guys I have a problem with the same power supply 48.L1E02.A03 its reading short on a few places im still new to this. Would be great if anyone could point me in the right direction
                                  R615 is short
                                  C 611 is short
                                  ZD601 is short
                                    Please post good clear pictures of YOUR board. R615 is 0.22 Ohm resistor, so what do you read on your meter. Pictures of C611, ZD601?
                                    • Nickkip
                                      • Sep 2013
                                      • 9
                                      Hi Thanks for your replay I will post a video up to youtube bit later on see if I can show what im getting as where the top of the board by r615 that part of the board is all going to grown.
                                      • Nickkip
                                        • Sep 2013
                                        • 9
                                        Have uploaded the video to Youtube had no one to hold the camera for me will upload a better one tomorrow but think you may be able to get the idea. all the top right is short
                                        http://youtu.be/ICJcvwSdgIQ
                                        • Nickkip
                                          • Sep 2013
                                          • 9
                                          here is a photo on other side
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                          • MORETTIGIAN
                                            by MORETTIGIAN
                                            Title:
                                            Description:
                                            Procedure performed:
                                            - Removed backplate
                                            - Reapplied thermal compound
                                            - Reassembled card
                                            09-18-2025, 12:14 PM
                                          • Borse2008
                                            by Borse2008
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
