Monitor uF (/microfad) rating
  • Solder
    • May 2011
    • 6
    The power supply and inverter board are all in one. A 1000uf 25v cap has failed. I was wondering if I could replace it with a 2200uf 25v cap or a 3300uf 25v cap without damaging the board. Or should I replace it with another 1000uf 25v cap just for good measure..The only other cap I have that's close is a 1000uf 16v an I think I'm sposed to go UP in voltage an not down...
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Monitor uF (/microfad) rating
    1) Replace with the same uF and voltage. You can go up in voltage, not down.
    2) For lcd monitors, they usually have a SMPS power supply which requires a low ESR (ohms) cap. A list of recommended caps are at
    https://www.badcaps.net/forum/showthread.php?t=2280
    3) PCBONEZ also teaches how to select a suitable replacement at
    https://www.badcaps.net/forum/showpo...30&postcount=7
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      4) I forgot to mention that most here will recommend that you replace all the capacitors except the largest one which rarely, but not never, fails.
      Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
      Certain brands and certain series are known to be bad.
        master hoarder
        • May 2008
        • 12175
        You CAN go down in voltage, but you first need to check the voltage present on the 1000uF 25v cap. If it's reasonably less than 16v (usually, 13v or less), then the 16v cap would likely be fine. Just make sure the voltage never goes over 16v and it should be no problem. I've done this many many times with no problems (after checking the voltage in the circuit first, of course).
        Sometimes, power supply manufacturers will use a capacitor with a higher voltage rating because the caps for the higher voltage are physically larger. When comparing caps of the same manufacturer and series, this means that the higher voltage caps will also have lower ESR than their lower voltage counterparts. This is usually a cost-cutting move by PSU manufacturers.
        • Solder
          • May 2011
          • 6
          If I had something to test the voltage to see what it was actually outputting then I'd stick the 16v cap on it...I got a 1000uf 35volt. But I had someone else put the cap on for me so I could prep the monitor to be put back together and he installed it backwards..the reverse in polarity caused the cap to vent within a minute of the monitor running. So now I gotta get another cap This can be marked are resolved.
            by momaka
            03-15-2023, 10:17 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • psyduck
            Conformal coating on Samsung U32D970 monitor PSU, do I need to replace after repair?
            by psyduck
            I have a Samsung U32D970 monitor from 2015 I pulled out of the bad hardware pile that turned on and then turned itself back off after a few minutes of use and refused to turn back on. The PSU has part number BN44-00786A, and I found a couple posts about one that had blown with damage to the MOSFETs and PWM controller - but nothing about intermittent failures. I started a new thread and said that I would refresh the solder joints on the board to see if it was just a bad connection and possibly replace the PWM and PFC ICs. I then asked what my next course of action would be after those steps. I...
            11-27-2023, 06:56 PM
          • wattage
            by wattage
            Hello Badcaps Community,
            07-13-2025, 04:41 PM
          • ant3202
            HP 27es - LED monitor - Monitor Flashing On - Off
            by ant3202
            Hi Everyone
            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
            https://www.badcaps.net/forum/troubl...lashing-on-off
            The monitor is HP 27es LED Monitor
            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
            The monitor will randomly blackout and display no signal and will recover again.
            Sometimes need to power and off again to restore the display but...
            03-20-2025, 07:30 PM
