Troubleshooting Acer AL2416w - Bad Capacitor?
  • ownlife
    • May 2011
    • 5
    After reading around this forum a while and locating this thread:
    https://www.badcaps.net/forum/showthread.php?t=9626
    My husband and I took apart his Acer monitor. The last two days it has refused to work. It will flash the Acer logo and then go black. We checked to see if it was the capacitors, but they look fine to us. He has already ordered a new monitor, but I was hoping to get his monitor working for my use or for a backup.
    Monitor has same results with VGA and DVI. We've tried shining a light on the monitor with a flashlight after the Acer logo goes away, but we see no image.
    Can anyone tell from the pics anything?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Troubleshooting Acer AL2416w - Bad Capacitor?
    1) Does the power LED stay green or blue after the Acer logo goes to black?
    2) If you hookup a working computer with your favourite wallpaper and shine a flashlight on the lcd, do you see the wallpaper? Your description above isn't clear to me if you had a working computer hooked up or not?
    3) Do you have a multimeter?
    4) The 10 caps on the inverter board can be problematic. Capacitors (C designation on the PCB board) die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
    --- begin sig file ---
    --- end sig file ---
    • Lumberjack777
      • 464
      Not from the pics. But from experience. I'd give it an 85% chance the problem is located on the 3rd picture. Your inverter board. There's several threads on this model already. We just finished helping "froggy" with his. He reported success today even.
      I think the most comprehensive thread was this one https://www.badcaps.net/forum/showth...hlight=AL2416w
      Basically. You'll be looking at replacing the little green mini-caps. A shorted transistor or two. And quite probably a fuse or two.
      If you have a multimeter, there's technicians here that can help you test those components to find out which ones have shorted.
      And if you don't have a multimeter. Get one. They are fairly inexpensive these days
      • Scenic
        o.O
        • Sep 2007
        • 2640
        http://www.youtube.com/watch?v=Xm0AJ65TGOI
        as your fault description sounds exactly the same
        edit: oh and those caps don't need to be bulging to be bad..
          by momaka
          03-15-2023, 10:17 PM
        • ADV
          Acer Ferrari F-20" monitor display interference and replacement capacitor selection
          by ADV
          Good day everybody
          I hope I'm posting in the right section - I am new to this awesome forum.
          I have received an ACER Ferrari F-20" LCD Monitor to repair.
          It produces interference lines on the image displayed and slowly rotates across the whole screen, with respect to the center of the screen. One rotation takes about 4 minutes and the cycle repeats over and over.
          For some reason the On Screen Display Menu is not affected when switched on with the Menu button.
          I opened the external 18V power supply and see no bulged capacitors...
          11-02-2021, 09:32 AM
        • maralexbar
          How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
          by maralexbar
          I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
          It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
          If anyone knows how to force the external monitor as primary for Notebooks of those models
          11-02-2024, 09:18 AM
          09-06-2024, 05:27 AM
        • tony359
          Bipolar capacitor for vintage Apple CRT monitor
          by tony359
          Good day all,
          I have a question about some old monochrome Apple monitors.
          Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
          A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
          The new capacitor:...
          08-12-2024, 03:27 AM
