Problems opening Viewsonic VA903B-2
  • markaren1
    Hi All,
    I have a busted unit and am quite sure that replacing the caps is going to fix most of the problems.
    First issue is how to remove the front of the display.
    I have unscrewed everything on the rear and the unit seems quite determined not to fall apart yet.
    Exploded views from the service manual indicates some recessed tabs attaching the front bezel to the rear molding.
    I am being vary wary about jamming in a screwdriver because I know I am damage the appearance of the unit.
    Any pointers how to gently take this unit apart will be most appreciated.
    Thanks,
    Mark.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Problems opening Viewsonic VA903B-2
    Originally posted by markaren1
    Hi All,
    Thanks,
    Mark.
    If it's like other Viewsonics, it's very difficult. There are several methods to separate the two pieces of the case - thin bladed screwdriver, putty knife, 'case popper', credit card, and my favorite, guitar pick. By starting at the bottom any evidence of prying will be hidden.
    PlainBill
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Butter knives.
      Mann-Made Global Warming.
      - Dr Seuss
      • PlainBill
        • Feb 2009
        • 7034
        Originally posted by PCBONEZ
        Butter knives.
        My wife would be upset if I tried this. I try to avoid upsetting her. She knows where I sleep, and she knows how to hurt me.
        "What is the best way to a man's heart?"
        "A sharp knife between the 5th and 6th ribs."
        PlainBill
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I really don't have to ask permission.
          But:
          I could afford the $2 to buy a dozen or so at goodwill to scatter about my tool boxes anyway.
          Much cheaper than screwdrivers even....
          - Dr Seuss
          • ngml
            Repair of an LG split AC system indoor unit PCB
            by ngml
            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
            This indicates an error in the communication between the outdoor and the indoor unit.
            The outdoor unit is fine, so the problem is the indoor PCB.
            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
            Does anybody have the schematics of this board,...
            02-01-2025, 12:55 PM
          • bauto601
            KDM 480W PSU upgrade succes! (opinions?)
            by bauto601
            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
            A "nice" YoungYear unit? - Badcaps
            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
            12-26-2023, 03:05 PM
          • jean luc ferre
            laptop hp g72 b52sf screen problems
            by jean luc ferre
            on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
            the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
            i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
            i don't understand the reasons of the white stripe at the bottom of the screen below the task...
            06-07-2025, 03:27 PM
          • nobbnobb1
            Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
            by nobbnobb1
            Hi guys,
            Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
            When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
            02-03-2022, 11:14 AM
          • Hondaman
            USB problems?
            by Hondaman
            Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
            (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
            I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
            08-12-2024, 03:26 PM
