Universal Backlight Inverter?
  • alexanna
    • Mar 2010
    • 1346
    Well I thought I open this for some discussion, and maybe get some ideas.
    I have a really nice 24” monitor that the Separate inverter is beyond repair. My thoughts are to use a universal 6 CCFL inverter. My question is that the monitor supplies 28v to the inverter when it's not under any load. Playing around with it I tried a 4 lamp inverter I had sitting around. The inverter I used was rated at 19v the voltage under a load dropped to right at 25v and everything seems to work except a really dark screen. If I install a 100 ohm resistor in the supply line the voltage drops well below 12v, and the inverter doesn't like the lower voltage [noisy and flickering ect.]
    I have found a universal 6 lamp inverter but it's rated at 12v with a 5 amp fuse protecting the circuit. The BL on and Dim pins should work
    If the capacitors on the inverter are rated at or above 25v is this something I need to worry about, or would there be an easy to figure what resistor I should use to drop the supply voltage down closer to 12V?
    There is not going to be a great deal of money involved for the inverter, so I would be willing to experiment, and share the information within this forum.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Universal Backlight Inverter?
    I doubt the inverter would survive with 25 volts applied. A fair amount of engineering went into designing that inverter to operate off 12 Volts. In particular, the transformers and driver transistors are likely to be damaged.
    Using a conservative estimate of 3A for the current required, the resistor would have to be a 50 watt resistor. I'd say it would be time to design a DC-DC bucking converter.
    PlainBill
    • Timorad
      • Mar 2011
      • 10
      A few days ago I was wondering the same thing about using a universal inverter (See another thread). The inverter input voltage is 20 volt, so I will need to downregulate it.
      I found a linear regulator 78S12 that does what I want (and is cheap), but it is designed for 2 amps max. According to what the powerboard reads (see photo below), 2A will be enough. Or am I misinterpreting this?
      It reads:
      12V/2.4A
      20/1.8A (Not clear from the picture)
      A second option is to hook the inverter directly to the 12v line. However, I don't think it is a good idea to have both the load of the inverter and logic boards on one line.
      Edit: It seems there is a 78T12 too, designed for 3A. Not really efficient though..
      • alexanna
        • Mar 2010
        • 1346
        I haven't decided exactly what I'm going to do, One option I am thinking is to use a 12V power brick that's rated at the correct amperage to power the 12V circuit,Space is really limited, and I would feel more comfortable to be able to have all the shields/covers installed.
        The back light on and dim pins would be powered by the regular monitors power supply.
        I am lucky; I have various bricks sitting around.
        Like I say I am unsure exactly I am going to do that's just on option.
        • Timorad
          • Mar 2011
          • 10
          That it ofcourse another option, but requires making a hole in the back of my screen. Not the most elegant solution I was kinda hoping to find a simple buck converter or any other simple/cheap device that does what I want.
          Back to my situation: unfortunately I do not have the schematics for the powerboard to determine whether the 12V line is enough to power both the logic and inverter board. This would ofcourse be the most optimal solution in my case. Perhaps there is an expert here that can shed more light on this matter?
          • Timorad
            • Mar 2011
            • 10
            I am looking for step down converters on ebay, and found the following links:
            http://cgi.ebay.com/High-Efficiency-...-/270675796876 (Up to 4A with heatsink)
            http://cgi.ebay.com/ULTRA-HIGH-Effic...-/270702265079 (up to 8A)
            • avr
              • Oct 2009
              • 6
              I also have a small question regarding this matter.
              I have a monitor without inverter (Dell 2007fpb). Luckily I have one inverter sitting around from another monitor (Viewsonic vp201b).
              Now Dell supplies around 19.3V to the inverter, and Viewsonic had 18V line. Would it be safe to use this Viewsonic inverter, or should I somehow try to drop the 19V to near 18V?
              • PlainBill
                • Feb 2009
                • 7034
                I'd give it a try as-is. The inverter supply is usually not well regulated, and can change by more than 10%.
                PlainBill
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  Need help to replace burned resistor in 350w atx psu
                  by mikey5791
                  Hi to all forum members,
                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                • artvandalai
                  What resistor ohm will work better to repair this waterpik?
                  by artvandalai
                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                  01-05-2025, 04:10 PM
                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 02:20 PM
